PowerPlant · AC regenerator
PowerPlant 12
Breathtaking dynamics and openness, in a compact chassis.
$5,999
Save up to $1,500 with a trade-in.
Options
Buy or audition near you
All dealers30-day in-home trial
The PS Audio Home Experience
Try it risk-free for 30 days in your own system. Love it or return it.
- Outside the US? Find your local dealer
Designed for a whole system, medium to large amps
- Output 1,200 VA
- Outlets (US) 8
- Wall input Standard 15 amp
- Screen 4.3-inch color touchscreen
What reviewers say
The benefits of the PS Audio Power Plant 12 on my front end were real and easily audible.
As good as the system had sounded with the P5, with the P12 there was a major step forward in overall realism.
…the deep, inky darkness coming from my system was quite unnerving. Once heard, it's difficult to forget.
Why choose it
Don't starve your music
Regenerated power for a whole system, from your sources to medium and large amplifiers. Expect far better dynamics and a cleaner, lower-noise background.
Don't starve your music.
Design
How it's built
01
Overview
PowerPlants are personal AC generators that provide hard-working, perfected results from the AC power line. Power regeneration uses active components, like those found in large, powerful audio amplifiers, to rebuild the AC power and produce clean, clear, distortion-free, regulated AC to the equipment.
Read more
PowerPlants are personal AC generators that provide hard-working, perfected results from the AC power line. Power regeneration uses active components, like those found in large, powerful audio amplifiers, to rebuild the AC power and produce clean, clear, distortion-free, regulated AC to the equipment. The results of feeding your equipment with low output impedance are dramatic: unrestrained dynamics even under the loudest passages, an open, wide soundstage that does not collapse with volume and a naturalness to the music that is remarkable. The 4.3-inch, full color display on the front panel of the P12 allows you to measure distortion, both incoming and outgoing, improvement levels, and power consumption. You can also adjust your settings, such as the turn on/off sequence and the output voltage, as well as turn individual zones on or off, and measure the power quality with either the built-in oscilloscope or the THD analyzer.
02
Output
The P12 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage.
Read more
The P12 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage. Low output impedance is critical to maintaining a dynamic presentation. Powering equipment through a passive power conditioner only worsens the problem and should be avoided. The Power Plant, on the other hand, has such low output impedance (0.008Ω vs. typical 0.4Ω) that even the hungriest of amplifiers won’t be starved for clean AC power. When your amp is asked to produce loud orchestral levels, you want to make sure it has all the power it needs and only a Power Plant provides a constant output regardless of the dynamic demands of equipment or your neighbors. Power Plants also generate new waveforms that enhance the capabilities of your equipment. MultiWave extends the peak charging time of the sine wave so connected equipment has more energy storage and less power supply ripple. The results are dramatic: a bigger more musically accurate soundstage than with a simple sine wave.
03
Protection
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment.
Read more
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment. Shielding devices from these potential electrical problems is mandatory if we're to protect our investment and ensure the safety of our homes. These electrical transients are not the only potentially damaging problems faced by our sensitive audio systems. There are also sustained over-voltage conditions that many surge suppression devices will not be able to protect equipment from. Owners who have invested in a Power Plant can rest assured their connected equipment will be safe from any power line event such as over voltage, under voltage, surges, spikes and potentially threatening problems. The input voltage to the Power Plant is fully protected by state-of-the-art clamping devices and the output of the Power Plant is fully regulated so even large voltage swings that would normally damage connected equipment are made safe by either clamping or regulating. In most cases, connected equipment enjoys the protection and performance benefits of fully regulated power, even under extreme circumstances.
Features
At a glance
- BUILT IN BOULDER
- 1200 VA OUTPUT
- 3x LOWER IMPEDENCE THAN P5 POWER PLANT
- 8x OUTLETS US
- 15AMP AC INPUT US
- 120 VOLT REGULATED US
- RANGE 95 – 145 VAC US
- 4x EU/AU/GR/UK OUTLETS
- 10AMP AC INPUT EU/AU/GR/UK
- 230 VOLT REGULATED EU/AU/GR/UK
- RANGE 200 –285VAC EU/AU/GR/UK
- 100% REGENERATED AC
- 4x OUTLETS
- PURE SINE WAVE
- MULTIWAVE
- INTEGRATED OSCILLOSCOPE
- THD METER
- IMPROVEMENT METER
- POWER METER
- CONTROL OVER THE LAN
- ADJUSTABLE OUTPUT VOLTAGE
- COLOR TOUCHSCREEN
- FIELD UPGRADEABLE
- 48 LBS.
- 17W x 4H x 14D
Specifications
Full specifications
Environment Specification |
US/JP |
Europe/Asia |
| Location | Indoor use only | Indoor use only |
| Duty Cycle | Suitable for continuous operation | Suitable for continuous operation |
| Moisture Sensitivity | Not sealed against moisture | Not sealed against moisture |
| Operating Humidity | <80%rh | <80%rh |
| Storage Temperature | -40C to +40C | -40C to +40C |
| Operating Temperature | 0C to 40C | 0C to 40C |
| Max Operating Altitude | 12,000’ (3500m) | 12,000’ (3500m) |
| Electrical Supply Nominal Rating | 120V 15A 60Hz US 100V 15A 50/60 Hz JP |
230V 10A 50/60Hz |
Instrument Specification |
| Unit Dimensions | 17” W x 14” D x 4” H (43cm W x 36cm D x 10.16 cm H) | 17” W x 14” D x 4” H (43cm W x 36cm D x 10.16 cm H) |
| Unit Weight | 37 lbs ( 16.7kg) | 37 lbs ( 16.7kg) |
| Shipping Dimensions | 24” x 21” x 10” ( 61cm x 53cm x 25cm) | 24” x 21” x 10” ( 61cm x 53cm x 25cm) |
| Shipping Weight | 48 lbs (21.7kg) | 48 lbs (21.7kg) |
| Nominal Input Voltage | 95 – 145 VAC | 200 –285VAC |
| Maximum Continuous Load | 1000VA | 1200VA |
| Maximum Peak Load | 3600VA | 3800VA |
| Voltage Regulation | 0.5V | 1V |
| Output Distortion (Resistive Load) | <0.5% | <0.9% |
| Output Distortion (Reactive Load) | <0.5% 0.1% typical |
<0.9% 0.1% typical |
| Output Impedance | <0.008 ohm | <0.008 ohm |
| Noise Reduction | 100kHz – 2MHz >80dB | 100kHz – 2MHz >80dB |
| Efficiency @1200 VA | >85% | >85% |
| Input Frequency | 45 – 65 Hz | 45 – 65 Hz |
| Under Voltage Limit | US - 90 V JP - 75 V |
174 V |
| Over Voltage Limit | US - 144 V JP - 120 V |
275 V |
| Energy Dissipation | 1020J | 1270J |
| Peak Current Surge | 90,000A | 90,000A |
| Max Surge Voltage | 6,000V | 6,000V |
| Clamp Level | 340V | 800V |
| DC Trigger Configuration | Tip Positive | Tip Positive |
| DC Trigger Voltage | 5 – 15Vdc | 5 – 15Vdc |
| Standby Power Consumption |
35 Watts |
30 Watts |
Compare
How it compares
| P3 | P12This one | P15 | P20 | |
| Price | $2,999 | $5,999 | $7,999 | $9,999 |
| Powers | Sources and small systems | Whole system, medium to large amps | Whole system, more amp headroom | Whole system, the largest amps |
| Output | 300 W · 900 W peak | 1,200 VA | 1,500 VA | 2,000 VA · 3,600 W peak |
| Outlets (US) | 6 | 8 | 10 | 16 |
| Wall input | Standard 15 amp | Standard 15 amp | Standard 15 amp | 15 or 20 amp |
| Screen | None. Remote control | 4.3-inch color touchscreen | Color touchscreen | 7-inch color touchscreen |
Trade Up and Save
Save up to $1,500 on your PowerPlant 12
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
- Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
- Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
- Send yours back. We email a return label number. You have 30 days to ship your trade.
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Reviews
More reviews
The component is filled with forward-thinking and evolved technology, which is refreshing. The logistics of how to plug my system into the PS Audio Power Plant 12 made life pretty easy, but it was the smooth, layered and detailed sound upgrade that most impressed me.
We all need some place to plug our gear into when we assemble a high-performance stereo system, but what if that power product could improve our system’s sound? Now we are talking, right?
One thing did surprise me.
How do you make a four thousand dollar headphone amplifier sound better? Well, give it a clean sine wave source of power…. even the Pass Labs HA-1 was improved with the DirectStream Power Plant 12's regenerated power, and that caused me to spend way more...
I know PS Audio is doing things differently, and I had a basic grasp of the technology, but the deep, inky darkness coming from my system was quite unnerving.
Once heard, it's difficult to forget. This non background, in conjunction with some superior cabling, allowed hyper details into the gulf that was the soundstage
With no change in volume setting, the sound was more dynamic. This was particularly noticeable with audiophile blockbuster CDs…. In my initial bout of listening, amplification was provided by the PS Audio Stellar M700s, and as it's likely that PSA "voiced" those amps with a...
There are several ways to do something about power for your hi-fi system.
You can install a completely new, separate power group for your precious audio equipment, use a filter to “wash things down” a bit, or deploy what is known as a regenerator. We don’t test this last category very often. But now we have one to...
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealerHear it in your own room
PowerPlant 12
$5,999
- 30-day in-home trialThe PS Audio Home Experience. Love it or return it.
- Save up to $1,500 with a trade-inCredit comes off the price at checkout.
PowerPlant 12
Details
This is clearly one of the most important pieces of audio equipment you can own. Expect far better micro and macro dynamics as well as a cleaner, lower noise background.
Don’t starve your music or risk damaging your equipment. A P12 gives you greatly improved performance and safety from just plugging into the wall socket and far better dynamics, bass and a much bigger, open soundstage than any passive power conditioner on the market. Why settle for anything but a Power Plant? Take one home and try it today.
This product qualifies for our risk free in-home trial in the continental United States when purchased directly from PS Audio. And, trade in and save. Let us repurchase your old equipment at its full and original retail price. We'll give it a good home and make sure you have the best power in the world. Just click the green Trade In and Save button above these words to take advantage.
Home Audition
Get 30 days to listen to your PowerPlant 12 and see if you like it. If not, send it back.
Shipping
UPS Ground USA
FedEx International
Power regenerator
PowerPlant 12
Our most powerful compact AC regenerator, the P12 regenerates new, safe, and pure AC from your home's power outlets for breathtaking improvement.
Overview
Output
Protection
What owners and reviewers say
The benefits of the PS Audio Power Plant 12 on my front end were real and easily audible. The component is filled with forward-thinking and evolved technology, which is refreshing. The logistics of how to plug my system into the PS Audio Power Plant 12 made life pretty easy, but it was the smooth...
One thing did surprise me. How do you make a four thousand dollar headphone amplifier sound better? Well, give it a clean sine wave source of power…. even the Pass Labs HA-1 was improved with the DirectStream Power Plant 12's regenerated power, and that caused me to spend way more time listening ...
I know PS Audio is doing things differently, and I had a basic grasp of the technology, but the deep, inky darkness coming from my system was quite unnerving. Once heard, it's difficult to forget. This non background, in conjunction with some superior cabling, allowed hyper details into the gulf ...
As good as the system had sounded with the P5, with the P12 there was a major step forward in overall realism. With no change in volume setting, the sound was more dynamic. This was particularly noticeable with audiophile blockbuster CDs…. In my initial bout of listening, amplification was provid...
There are several ways to do something about power for your hi-fi system. You can install a completely new, separate power group for your precious audio equipment, use a filter to “wash things down” a bit, or deploy what is known as a regenerator. We don’t test this last category very often. But ...
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand and we credit its full original retail value against this one — up to a per-component cap that appears the moment you start a trade. See what yours is worth.
Hear it first
Every piece comes with a 30-day in-home trial. PMG Signature pieces get 60 days, with return shipping on us.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
At home
Where it disappears into the music.
Overview
Output
Protection
Recommended products
Specifications
US/JP |
Europe/Asia |
230V 10A 50/60Hz |
174 V |
275 V |
35 Watts |
30 Watts |
