PowerPlant · AC regenerator
PowerPlant 20
Trusted to power the most expensive systems in the world.
$9,999
Save up to $2,500 with a trade-in.
Options
Buy or audition near you
All dealers
30-day in-home trial
The PS Audio Home Experience
Try it risk-free for 30 days in your own system. Love it or return it.
Designed for a whole system, the largest amps
  • Output 2,000 VA · 3,600 W peak
  • Outlets (US) 16
  • Wall input 15 or 20 amp
  • Screen 7-inch color touchscreen
What reviewers say
Were it not for PS Audio's regenerators, I'd be out of business
SStereophileMichael Fremer, 2018
You won't be able to un-hear it, and you won't be able to live without it.
TTone AudioJeff Dorgay, 2018
The P20 sounded noticeably better, in all the same ways: naturalness, detail, image precision, soundstage depth and width.
SStereophileJim Austin, 2018
Why choose it
Power for the most demanding systems
2,000 watts of pure regenerated power, and the first PowerPlant to accept both 20 amp and 15 amp power cables. Enough for an entire system, including the largest amplifiers.
Don't starve your music.
Design
How it's built
01
Overview
When it comes to regenerated AC power we wrote the book. With two decades of engineering and a patented architecture in hand we built the biggest and best Power Plant ever.
Read more
When it comes to regenerated AC power we wrote the book. With two decades of engineering and a patented architecture in hand we built the biggest and best Power Plant ever. The P20 converts your home’s variable, compromised AC power into pure DC, then back again into safe, protected, regulated, perfect AC. The P20 will improve system performance like nothing else. DirectStream Power ushers in a new world of purity with a clean, analog-like DSD generator. With twice the number of output devices and double the power supply storage of any previous Power Plant, DirectStream P20 is the new benchmark for power products. Regardless of the quality of AC coming into P20, your equipment is guaranteed clean, safe power, with significantly lower distortion than ever before. Safe, regulated to within 1/10th of a volt, P20 provides unquestionable purity for systems of all sizes. The 7-inch, full color display on the front panel of the P20 allows you to measure distortion, both incoming and outgoing, improvement levels, and power consumption. You can also adjust your settings, such as the turn on/off sequence and the output voltage, as well as turn individual zones on or off, and measure the power quality with either the built-in oscilloscope or the THD analyzer.
02
Output
The P20 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage.
Read more
The P20 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage. Low output impedance is critical to maintaining a dynamic presentation. Powering equipment through a passive power conditioner only worsens the problem and should be avoided. The Power Plant, on the other hand, has such low output impedance (0.008Ω vs. typical 0.4Ω) that even the hungriest of amplifiers won’t be starved for clean AC power. When your amp is asked to produce loud orchestral levels, you want to make sure it has all the power it needs and only a Power Plant provides a constant output regardless of the dynamic demands of equipment or your neighbors. Power Plants also generate new waveforms that enhance the capabilities of your equipment. MultiWave extends the peak charging time of the sine wave so connected equipment has more energy storage and less power supply ripple. The results are dramatic: a bigger more musically accurate soundstage than with a simple sine wave.
03
Protection
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment.
Read more
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment. Shielding devices from these potential electrical problems is mandatory if we're to protect our investment and ensure the safety of our homes. These electrical transients are not the only potentially damaging problems faced by our sensitive audio systems. There are also sustained over-voltage conditions that many surge suppression devices will not be able to protect equipment from. Owners who have invested in a Power Plant can rest assured their connected equipment will be safe from any power line event such as over voltage, under voltage, surges, spikes and potentially threatening problems. The input voltage to the Power Plant is fully protected by state-of-the-art clamping devices and the output of the Power Plant is fully regulated so even large voltage swings that would normally damage connected equipment are made safe by either clamping or regulating. In most cases, connected equipment enjoys the protection and performance benefits of fully regulated power, even under extreme circumstances.
Features
At a glance
  • BUILT IN BOULDER
  • 2000 VA OUTPUT
  • 40% MORE POWER
  • 16x OUTLETS US
  • 15AMP AC INPUT US
  • 20AMP AC INPUT US
  • RANGE 95 – 145 VAC US
  • 120VOLT REGULATED US
  • 13AMP AC INPUT EU/AU/GR/UK
  • 230 VOLT REGULATED EU/AU/GR/UK
  • RANGE 200 –285VAC EU/AU/GR/UK
  • 13x EU/AU/GR/UK OUTLETS
  • PASSIVELY COOLED
  • PURE SINE WAVE
  • MULTIWAVE
  • INTEGRATED OSCILLOSCOPE
  • THD METER
  • IMPROVEMENT METER
  • POWER METER
  • CONTROL OVER THE LAN
  • ADJUTABLE OUTPUT VOLTAGE
  • COLOR TOUCHSCREEN
  • FIELD UPGRADEABLE
  • 100% REGENERATED AC
Specifications
Full specifications
Environment Specification
US/JP
Europe/Asia
Location Indoor use only Indoor use only
Duty Cycle Suitable for continuous operation Suitable for continuous operation
Moisture Sensitivity Not sealed against moisture Not sealed against moisture
Operating Humidity <80%rh <80%rh
Storage Temperature -40C to +40C -40C to +40C
Operating Temperature 0C to 40C 0C to 40C
Max Operating Altitude 12,000’ (3500m) 12,000’ (3500m)
Electrical Supply Nominal Rating 120V 15A 60Hz US
100V 15A 50/60 Hz JP
230V 10A 50/60Hz
Instrument Specification
Unit Dimensions 17” W x 14” D x 11” H (43cm W x 36cm D x 27.9 cm H) 17” W x 14” D x 11” H (43cm W x 36cm D x 27.9 cm H)
Unit Weight 96 lbs ( 43.5kg) 96 lbs ( 43.5kg)
Shipping Dimensions 23” x 22” x 17” ( 58cm x 55.8cm x 43 cm) 23” x 22” x 17” ( 58cm x 55.8cm x 43cm)
Shipping Weight 105 lbs (47kg) 105 lbs (47kg)
Nominal Input Voltage 95 – 145 VAC 200 –285VAC
Maximum Continuous Load 2000VA 2000VA
Maximum Peak Load 3600VA 3600VA
Voltage Regulation <1V <1V
Output Distortion (Resistive Load) <0.5% <0.5%
Output Distortion (Reactive Load) <0.5%
0.1% typical
<0.5%
0.1% typical
Output Impedance <0.005 ohm <0.005 ohm
Noise Reduction 100kHz – 2MHz >80dB 100kHz – 2MHz >80dB
Efficiency @1500 VA >85% >85%
Standby Power Consumption 35W 45W
Input Frequency 45 – 65 Hz 45 – 65 Hz
Under Voltage Limit
US - 90V
JP - 75V
175V
Over Voltage Limit
US - 144V
JP - 120V
275V
Energy Dissipation 2040J 5040J
Peak Current Surge 180,000A 180,000A
Clamp Level 340V 775V
DC Trigger Configuration Tip Positive Tip Positive
DC Trigger Voltage 5 – 15Vdc 5 – 15Vdc
Compare
How it compares
P3P12P15P20This one
Price$2,999$5,999$7,999$9,999
PowersSources and small systemsWhole system, medium to large ampsWhole system, more amp headroomWhole system, the largest amps
Output300 W · 900 W peak1,200 VA1,500 VA2,000 VA · 3,600 W peak
Outlets (US)681016
Wall inputStandard 15 ampStandard 15 ampStandard 15 amp15 or 20 amp
ScreenNone. Remote control4.3-inch color touchscreenColor touchscreen7-inch color touchscreen
Trade Up and Save
Save up to $2,500 on your PowerPlant 20
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
  1. Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
  2. Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
  3. Send yours back. We email a return label number. You have 30 days to ship your trade.
Start your trade-in
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Reviews
More reviews
P20 further improved crispness, expression, and clarity.
At this point, the raw power was unlistenable, making the system sound confused, blurred, rough, and shouty
CChristiaan Punter hifi-advice2025
Read the full review
I have everything plugged into it and simply find our music to be more dynamic and alive.
Greater separation and resolution…and all with no hint of harshness or whatever. No glare or grit. But, more visceral and, well... more overall engagingly so….Bass seems to go lower with a wonderful sense of tightness… or rightness, especially as evident from the subs in the...
DDave Clark, Positive Feedback2019
The P20 and P15 series products connect live and reproduced sound in a way that cannot be achieved any other way if dirty power is a culprit, and dirty power is almost always a culprit.
If you are planning to build a great system, addressing the very element that brings these inanimate boxes to life, these products should be a priority. Your music will thank you
GGreg Petan, Positive Feedback2019
I loved the P10, but the P20 offered all of that and a lower noise floor with even better transient response on dense classical music passages (massed strings), percussion notes occupying the space between the lowest octaves and improved vocal inflection, never mind an even more effortless sense of breathing to amps and preamps.
Throw in twice the number of output devices and double the power-supply storage of the P10 and upgrading became a no-brainer
RRafe Arnott, AudioStream2019
How does the DirectStream Power Plant 20 compare, sonically, to the P10 Power Plant?...
I did do some comparative listening. The P20 sounded noticeably better, in all the same ways: naturalness, detail, image precision, soundstage depth and width. I've come to consider my PerfeposictWave P10 Power Plant an essential reviewing tool, less because of the improvement it makes in...
JJim Austin, Stereophile2018
Would it be necessary to provide specifics on how my system sounded better with my system connected to the P20 versus how it sounded when not connected? I'd end up reciting a litany of audiophile approved characteristics, all positive, such as an increased frequency response in both the highs and lows, a more transparent midrange, greater attack, longer decay times, a larger, deeper, more detailed and more properly drawn to scale soundstage when appropriate, a sense of increased dynamics
TTom Lyle, Enjoy the Music2018
Read all 9 reviews
I'm gonna violate the prime directive and tell you to get one.
You won't be able to un-hear it, and you won't be able to live without it. So be ready to pull the trigger when you take the test drive. Consider yourself warned. It's that good
JJeff Dorgay, Tone Audio2018
Tone, and timbre of instruments are spot-on, with wood-bodied ones in particular in possession of the proper scale, weight, and resonance that I associate with real acoustic guitars.
Organ, and piano notes are mellifluous, and the slide guitar, and horn arrangements have a burnished, brassy flavor. Opting in to the P20, the already big, hip-shaking bottom end seems to swell in size, and weight, with a deeper tonal shading now coming through. Vocals...
RRafe Arnott, Part Time Audiophile2018
MMichael Fremer, Stereophile2018
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Hear it in your own room
PowerPlant 20
$9,999
  • 30-day in-home trialThe PS Audio Home Experience. Love it or return it.
  • Save up to $2,500 with a trade-inCredit comes off the price at checkout.
Add to cartTrade up your gear and save
Skip to product information
Silver
href="/products/directstream-power-plant-20?variant=43692396380450" class="link" >PowerPlant 20
PowerPlant 20
<strong>PS Audio's largest and most powerful regenerator, the P20 is trusted to protect and power the most expensive systems in the world.</strong>
The DirectStream P20 Power Plant is our finest expression of the art of delivering protected, pure, regulated, distortion-free AC power. With peak power levels of 3600 watts, no equipment can tax the mighty P20. Finally, your most coveted components have the opportunity to unleash their full potential. DirectStream P20 regulates both long-term fluctuations and peak dynamics without deviation, ensuring a solid foundation from which to build a state-of-the-art system. Its low output impedance and unhindered AC delivery are equivalent to less than 50 feet of 12 gauge wire connected directly to your city power source without the connecting miles of wire, the many transformers, and the multiple neighbors weakening and contaminating your power.
$9,999.00
Overview
Output
Protection
What owners and reviewers say
P20 further improved crispness, expression, and clarity. At this point, the raw power was unlistenable, making the system sound confused, blurred, rough, and shouty
Christiaan Punter hifi-advice · Read full review
I have everything plugged into it and simply find our music to be more dynamic and alive. Greater separation and resolution…and all with no hint of harshness or whatever. No glare or grit. But, more visceral and, well... more overall engagingly so….Bass seems to go lower with a wonderful sense of...
Dave Clark, Positive Feedback · Read full review
The P20 and P15 series products connect live and reproduced sound in a way that cannot be achieved any other way if dirty power is a culprit, and dirty power is almost always a culprit. If you are planning to build a great system, addressing the very element that brings these inanimate boxes to l...
Greg Petan, Positive Feedback · Read full review
I loved the P10, but the P20 offered all of that and a lower noise floor with even better transient response on dense classical music passages (massed strings), percussion notes occupying the space between the lowest octaves and improved vocal inflection, never mind an even more effortless sense ...
How does the DirectStream Power Plant 20 compare, sonically, to the P10 Power Plant?... I did do some comparative listening. The P20 sounded noticeably better, in all the same ways: naturalness, detail, image precision, soundstage depth and width. I've come to consider my PerfeposictWave P10 Powe...
Jim Austin, Stereophile · Read full review
Would it be necessary to provide specifics on how my system sounded better with my system connected to the P20 versus how it sounded when not connected? I'd end up reciting a litany of audiophile approved characteristics, all positive, such as an increased frequency response in both the highs and...
Tom Lyle, Enjoy the Music · Read full review
I'm gonna violate the prime directive and tell you to get one. You won't be able to un-hear it, and you won't be able to live without it. So be ready to pull the trigger when you take the test drive. Consider yourself warned. It's that good
Jeff Dorgay, Tone Audio · Read full review
Tone, and timbre of instruments are spot-on, with wood-bodied ones in particular in possession of the proper scale, weight, and resonance that I associate with real acoustic guitars. Organ, and piano notes are mellifluous, and the slide guitar, and horn arrangements have a burnished, brassy flavo...
Rafe Arnott, Part Time Audiophile · Read full review
Michael Fremer, Stereophile · Read full review
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand and we credit its full original retail value against this one — up to a per-component cap that appears the moment you start a trade. See what yours is worth.
Hear it first
Every piece comes with a 30-day in-home trial. PMG Signature pieces get 60 days, with return shipping on us.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
PowerPlant 20
At home
Where it disappears into the music.
Try it at home $9,999.00
Take it home
Design
The PerfectWave PowerPlant 20 is PS Audio's finest pure power delivery system. Equipped with 16 outlets (US version) across 5 separate regenerated zones, the P20 can take input from either 15 or 20 amp lines to regenerate a completely new AC waveform, free of distortion or voltage fluctuations. The P20 features an ultra-low impendance analog power amplifier and FPGA based DSD engine that delivers the cleanest, lowest noise sine waves of any regenerator in the world.
Application
The P20 can provide clean power to even the biggest, most elaborate audio system. With a maximum output of 2000 watts, and peak power levels of 3600 watts, the P20 will provide pure power for the most demanding components and reproduce the full dynamic range of any music thrown at it. Regulated to within 1/10th of a volt, the P20 provides, safe, unquestionable purity for systems of all sizes and ensures a solid foundation from which to build a state-of-the-art system.
Overview
Output
Protection
Features
24 key features
BUILT IN BOULDER
2000 VA OUTPUT
40% MORE POWER
16x OUTLETS US
15AMP AC INPUT US
20AMP AC INPUT US
PASSIVELY COOLED
PURE SINE WAVE
MULTIWAVE
THD METER
IMPROVEMENT METER
POWER METER
COLOR TOUCHSCREEN
FIELD UPGRADEABLE
100% REGENERATED AC
Reviews
9 reviews
Read full review →
I have everything plugged into it and simply find our music to be more dynamic and alive. Greater separation and resolution…and all with no hint of harshness or whatever. No glare or grit. But, more visceral and, well... more overall engagingly so….Bass seems to go lower with a wonderful sense of tightness… or rightness, especially as evident from the subs in the Vandersteens. Slam and punch, texture and presence. Palpable as all get out, and, as I said, texture… oh man… where there is
Read full review →
The P20 and P15 series products connect live and reproduced sound in a way that cannot be achieved any other way if dirty power is a culprit, and dirty power is almost always a culprit. If you are planning to build a great system, addressing the very element that brings these inanimate boxes to life, these products should be a priority. Your music will thank you
Read full review →
I loved the P10, but the P20 offered all of that and a lower noise floor with even better transient response on dense classical music passages (massed strings), percussion notes occupying the space between the lowest octaves and improved vocal inflection, never mind an even more effortless sense of breathing to amps and preamps. Throw in twice the number of output devices and double the power-supply storage of the P10 and upgrading became a no-brainer
How does the DirectStream Power Plant 20 compare, sonically, to the P10 Power Plant?... I did do some comparative listening. The P20 sounded noticeably better, in all the same ways: naturalness, detail, image precision, soundstage depth and width. I've come to consider my PerfeposictWave P10 Power Plant an essential reviewing tool, less because of the improvement it makes in the sound—although that is, of course, important—than because it levels the playing field for the equipment I review
Read full review →
Read full review →
Read full review →
Tone, and timbre of instruments are spot-on, with wood-bodied ones in particular in possession of the proper scale, weight, and resonance that I associate with real acoustic guitars. Organ, and piano notes are mellifluous, and the slide guitar, and horn arrangements have a burnished, brassy flavor. Opting in to the P20, the already big, hip-shaking bottom end seems to swell in size, and weight, with a deeper tonal shading now coming through. Vocals take on a sweeping, more expansive quality
Read full review →
Read full review →
Want to leave your own review?
Specifications
Technical details
US/JP
Europe/Asia
230V 10A 50/60Hz
0.1% typical
<0.5%
0.1% typical
Under Voltage Limit
US - 90V
JP - 75V
175V
Over Voltage Limit
US - 144V
JP - 120V
275V
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Recommended products
