Physical |
| Unit Weight | 21 lbs [9.53 kg] |
| Unit Dimensions | 14” x 17” x 4” [ 36cm x 43cm x 10cm] |
| Shipping Weight | 30 lbs [13.6 kg] |
| Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
Power requirements |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 25W |
Digital audio inputs |
I2S (2), Coax, XLR Balanced (2), Optical, USB |
Sample Rates |
Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz
S/PDIF and AES3: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64 Dual AES3: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz and 352.8kHz; DoP64 and DoP128 I2S: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256 USB: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256 |
Analog Audio Output |
| Connector | RCA single ended or balanced, XLR balanced |
| Output level high, maximum | 4 VRMS Balanced 2 VRMS Single Ended |
| Output Impedance | <100Ω/<200Ω |
| Frequency Response | 20-20KHz +/- 0.25dB |
| THD+N @ 1KHz (full scale) | <0.1% |
| Output Stage | Passive audio transformer, fed by high current, high speed analog amps producing double rate DSD |
Data Handling |
| Format | PCM or DSD |
| Sample rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz; 705.6kHz |
| Word length (PCM) | 16b, 18b, 20b, 24b |
| Data rate (DSD) | Standard (2.8MHz) or Double (5.6MHz) DoP as well as raw DSD on I2S and USB inputs |
| Input jitter reduction | effectively 100%, residual immeasurable. No input PLLs, FLLs. |
| Input Processing | 225.792MHz |
| Signal Processing | 56.448MHz |
| Synchronous Upsampling, all inputs | 56.448MHz for 48k, 96k or 192k; 11.2896MHz for all others |
| Digital Processing S/N ratio | Upsampling > 210dB, volume control and Sigma Delta Modulator: > 330dB |
| Digital Volume Control | Zero loss of precision |
| Analog Conversion method | low pass filter DSD256 (quad rate DSD: single bit DSD at 11.2896MHz) |
I2S Digital Input |
| Connector | HDMI |
| Format | PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs |
USB Digital Input |
| Connector | USB “B” Type |
| Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
| Transfer mode | Asynchronous |
DirectStream DAC MK2
Design
Application
Galvanic Isolation
DSD to analog
Output and Volume
Features
17 key features100% DSD BASED D-A CONVERTER
UPGRADABLE VIA SOFTWARE RELEASES
VOLUME, BALANCE CONTROL BUILT IN
UPSAMPLES PCM AND DSD TO 20x DSD RATE
DXD SUPPORT
PASSIVE TRANSFORMER COUPLED OUTPUT
IMPROVES IMAGING + SOUNDSTAGE
DUAL FPGA PROCESSING
HANDWRITTEN FILTERS, PROCESSING AND UPSAMPLERS
IMMUNE TO OUTSIDE SOURCE JITTER PROBLEMS
INCREASED DIGITAL HEADROOM
NO OFF-THE-SHELF IC-DAC CHIPS USED
UNCOVERS DETAILS USUALLY MASKED BY PCM PROCESSORS
7x DIGITAL INPUTS
GALVANICALLY ISOLATED INPUTS AND OUTPUTS
FULLY BALANCED FROM INPUT TO OUTPUT
STORE AND INSTALL UP TO 10 FIRMWARE MOUNTAINTOPS
Reviews
5 reviews
Reproduction of low-level detail is also a strong suit, with very fine rendering against a jet-black background.
Read full review →
While the PerfectWave DirectStream DAC garnered a lot of buzz when it was released, my guess is a veritable chorus of accolades will soon be surrounding the DirectStream DAC MK2. If my budget only allowed for an ,000 DAC, I would give this one a very, very serious listen. Given its retail cost, it will effectively raise the bar on delivering a magnificent audio experience
Read full review →
The same size as its well-regarded predecessor, the MK2 processor replaces the rectangular, four-color touchscreen with a smaller display with a Mute/Menu button to its left and a blue-illuminated five-button controller to its right. However, it still upsamples PCM data to 30-bit words, now sampled at 2× the original's 28.224MHz
Read full review →
For sure the DirectStream DAC MK2 reflects the people at PS Audio and especially Ted Smith, who writes the firmware/software that has a major role in how the DirectStream DAC MK2 sounds. Of which, sounds neither bright, dull, rolled off, hyped, lean... sounds like what we want our music to sound like. Wait... come to think of it, the DirectStream DAC MK2 sounds like Ted; humble, honest, and truthful, all the while being playful and fun. Full of color and joy
Read full review →
Equipment like the Perfect Wave Direct Stream DAC MK2 from PS Audio shows that some 40 years of advances have made the best digital sound far more musical and realistic, and the best highest-resolution PCM, DSD, and DSD/SACD discs and streaming now outperform the best-sounding LPs that I’ve heard
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
