Physical |
| Unit Weight | 22 lbs [9.97 kg] |
| Unit Dimensions | 17” x 14” x 4” [ 36cm x 43cm x 10cm] |
| Shipping Weight | 31 lbs [14 kg] |
| Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
Power requirements |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 60W |
Audio inputs |
| Coaxial RCA single ended XLR Balanced |
5 5 |
| Input Impedance Unbalanced (RCA) Balanced (XLR) |
33KΩ minimum 66KΩ minimum |
| Sensitivity | Unbalanced 1.3V/33KΩ Balanced 1.3V/66KΩ |
Audio Outputs |
2 2 |
Analog Audio Output |
| Output level | 4.0 Vrms |
| Output Impedance | <100Ω |
| Frequency Response 20-20KHz |
+/- 0.1dB |
| THD&IM @ 1KHz (full scale) | <0.03% |
| Bandwidth | -3dB 0.1Hz - 200kHz |
DC Triggers |
| +12V | 2 |
Headphone Performance |
| Output Power 300Ω 16Ω > |
>200mW 4.0 Watts |
| S/N Ratio | >90dB (1KHz) |
| THD & IM 1 volt out | <0.02% |
| Output Impedance | <0.5Ω |
BHK Signature Preamplifier
Closeout special is not trade-in eligible
Design
Application
Overview
Inside Story
The Build
Features
19 key featuresZERO-LOSS VACUUM TUBE INPUT STAGE
12V AND 6V TUBE SWITCH
COUPLED & BALANCED MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
PRP RESISTORS IN SIGNAL PATH
5x RCA SINGLE ENDED INPUTS
5 XLR BALANCED INPUTS
SINGLE ENDED & BALANCED INPUTS
FULLY BALANCED INPUT TO OUTPUT
OVERSIZED POWER TRANSFORMER
BHK DESIGNED MOSFET VOLTAGE REGULATORS
BHK DESIGNED MOSFET HEADPHONE STAGE
REMOTE CONTROL
STANDBY BUTTON FOR VACUUM TUBE STAGE
-3dB > 200kHz
VOLUME & BALANCE THROUGH GAIN & ATTENUATION CONTROL
2x OUTPUT DC CONTROL TRIGGERS
EASY ACCESS TO TUBES FOR CUSTOMIZATION
EACH INPUT CAN BE SET TO HT BYPASS
Reviews
5 reviews
In the BHK Signature preamplifier, Bascom H. King has designed, and PS Audio has built, an outstanding performer. It possesses the top-quality fit and finish that one would expect to get for 999. Its sound was beautiful and alive, re-creating three-dimensional soundstages that were the largest I've heard in my room. Its excellent clarity of sound let me easily decipher even the most complex music, its bass was superbly firm, deep, and controlled, and its treble extension was clear and
Read full review →
PS Audio's BHK Signature preamp is one of the finest audio components I've had in my home. It didn't raise the dead, but it could conjure in my listening room the spirits of dead musicians, or fine facsimiles thereof. It didn't solve my problems, but it could sure distract me from them—and, with the right recordings, even trigger catharsis or philosophical insight
Read full review →
What the PS Audio BHK Signature Preamplifier brings to the table is a significant achievement. For me, it seals the deal, and I believe it will satisfy audiophiles on both sides of the aisle (digital versus analog, tubes versus solid state), and those in between. Taking into consideration its price, simplicity of use, extraordinary quality of sound, design and features such as an included internal headphone amp, I must honestly say, 'There is no preamp like this preamp'. Very highly recommended
Read full review →
Synergy and magic. Right now here in our listening room...Way deeper bass, way more open, way less whatever being in the way of our music… way more music. Dynamics… try My Disco's "1991" or anything from Lustmord. Happy times
Read full review →
The Signature is the most transparent and neutral of the active preamps, giving added life and expression, but otherwise stepping out of the way of the music. Bottom line, the PS Audio BHK Signature Preamplifier is the ultimate witness to the music: It tells the truth, the whole truth, and nothing but the truth
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
