Skip to product information
Silver
href="/products/bhk-signature-250-amplifier?variant=43692265931042" class="link" >BHK Signature 250 Amplifier
<strong>The BHK 250 stereo power amplifier is an industry reference standard for performance—a 250 watt per channel investment grade musical instrument that brings life to music.</strong>
The BHK Signature 250 Stereo Power Amplifier culminates one man’s lifelong quest for perfection in power amplification. Bascom H. King’s magnum opus combines a vacuum tube input with a powerful MOSFET output capable of 250/500 watts per channel. When cost-no-object performance is the goal there are a rare handful of power amplifiers capable of transporting listeners into a musical space few are able to enjoy. The BHK Signature 250 is one such amplifier. Lush, gorgeous, powerful, revealing, hand built, perfect. If you are uncomfortable with compromise and seek the finest performance, reliability, and build quality in a single-chassis format, the BHK Signature 250 is a perfect fit.
Discontinued from new production in 2024
Sale price  $4,249.00 Regular price  $8,499.00
Design
Nothing in the design of a power amplifier is more important than its input stage when preserving music’s finest nuances. In the BHK Signature, a vacuum tube serves as the perfect interface between the preamplifier and MOSFET output stage. This hybrid approach offers stunning musical performance and unrivaled, effortless drive to the speaker. The Signature 250 Stereo Amplifier is the ultimate choice when a single chassis solution is required.
Application
The BHK Signature 250 Stereo Amplifier produces 250 watts/ channel into an eight-Ohm loudspeaker, 500 watts/channel into four-Ohms, and stable into 2-Ohms; enough power to satisfy even the hungriest of loads. Use this amplifier as the bedrock of your high-performance audio or home theater system. The BHK 250 provides the finest performance, reliability and build quality possible, in a single chassis format.
Overview
The importance of the power amplifier in the 2-channel system chain cannot be overstated, yet it's often overlooked. It's the rare few music lovers that truly appreciate the power amp's critical role in preserving music's nuanced details, because most amplifiers fail to preserve them. Overtones from plucked instruments, subtle cues defining placement, depth, soundstage width, and transient decays are often lost in the power amplifier. Suddenly revealed are the tiniest of details that now ring clear through the BHK, perfectly preserved through its low feedback, vacuum tube and MOSFET design. When it comes to musically controlling and powering loudspeakers, the BHK Signature has few peers at any price. The stereo Signature 250 produces 250 watts/per channel into an eight-Ohm loudspeaker, 500 watts/channel into four-Ohms, and stable into 2-Ohms; enough power to satisfy even the hungriest of loads.
Input Stage
A power amplifier’s input stage is a critical interface in the quest to preserve music’s essential details and vacuum tubes do it best. Hand matched pairs of Russian Gold Lion 6922s provide the perfect interface between the delicate musical transitions output by the DAC or preamplifier, transferring it without loss to the MOSFET output power stage and eventually the loudspeakers. The hybrid approach used in the BHK Signature takes advantage of the best traits technology has to offer, unavailable in traditional solid state or tube designs. While vacuum tubes are the perfect input stage, they cannot make the same claim on a power amplifier's output. Conversely, solid state designs are correct for output stages, but suffer when used as inputs. Only a hybrid approach takes advantage of the best in both disciplines.
Output stage
A power amplifier connects its reservoir of energy to the loudspeaker through a type of valve (solid state or vacuum tube) controlled by the input stage. If the input stage has done a good job of preserving music's subtle details, textures, timing and phase information, transferring it without loss to the power stage and eventually the loudspeakers is best handled by a tube-like solid state device known as a MOSFET. Not all MOSFETs are the same, their differences characterized by their relationship with the input signal and the power supply driving them: N-types for the positive going signals, P-types for negative. N-types have lower distortion and perform better than P-types but N-channel-only amplifiers are rare. Using only N Channel MOSFETS in its output stage, the BHK Signature produces a near-perfect balanced waveform without the degradation inherent in a complementary design.
Features
16 key features
ZERO LOSS INPUT TUBE
POWERFUL MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
RCA SINGLE-ENDED INPUT
XLR "TRUE" BALANCED INPUT
250 WATTS PER CHANNEL 8Ω
500 WATTS PER CHANNEL 4Ω
2Ω STABLE
-3dB > 200khz
< 0.1% THD 20Hz - 20kHz AT RATED POWER
DAMPING FACTOR = 100
FRONT PANEL STANDBY BUTTON
BALANCED INPUT TO OUTPUT
DUAL, COPPER, PLATED, OUTPUT BINDING POSTS
83 LBS.
INPUT 12 VOLT TRIGGER
Reviews
5 reviews
Dave Clark, Positive Feedback
I can't recommend the BHK 250 enough. Like I said I bought this one and it is now here between the speakers with the Claytons off on a rack. I won't sell the Claytons ever and for sure they will eventually find their way back into the system
Read full review →
Giulio Salvioni, Fedeltà del Suono
The PS Audio BHK Signature 250 has everything that one would expect from a power amplifier of this category: it's powerful, fast, accurate, gentle regarding its ability to convey the harmonic complexity of even the most difficult audio tracks and has a great dynamic reserve. Its ability to recreate a coherent and well focused soundstage puts this product among the best power amplifiers regarding this parameter. I could go on for a while extrapolating specific parameters and writing about how
Deon Schoeman, Audio Video Magazine
Yes, it's all things you'd expect from a top flight amplifier: powerful and precise, fast and dynamic, generous in its staging, and close in its focus. But its ability to translate those elements into a musically coherent and consistently compelling performance is what sets the BHK Signature apart from any other power amplifier I've listened to. I sense a classic in the making
Eric Neff, HiFi Plus
Bascom, Paul, and Arnie's combined 150 years of audio excellence has led to a design of classic physical beauty and sonic excellence that easily achieves the goal of competing with über-level amplifiers, but at a fraction of the retail price. As audiophiles, we sometimes fall into the 'price equals performance' trap. We fear being the emperor with no clothes when our friends ask how much we paid and it was, gasp! LESS than what flagship gear is supposed to cost. Naturally it must not be that
Read full review →
Frank Alles, Stereo Times
I confess I have no criticism of the BHK 250's sonic performance—only high praise. It is extended and detailed at both frequency extremes and has an immediate, musical, and open sounding midrange (all qualities I love)…. Although the PS Audio BHK Signature 250 stereo amplifier is higher priced than most amplifiers I have used, for an amplifier of this pedigree and obvious premium quality I believe it is quite the bargain at its current ,499 price tag. In fact, I would seriously consider
Read full review →
Want to leave your own review?
Specifications
Technical details
BHK Signature 250 Stereo and BHK Signature 300 Mono
Unit Weight 83 lbs [37.6 kg]
Unit Dimensions 17.1” x 8.7” x 14” Chassis only. 15" deep including connectors.
Shipping Weight 92 lbs [41.7 kg]
Shipping Dimensions 21”x 13” x 19”
Color Options Black
Silver
Voltage Options
Factory set only
Japan 100V
North America 120V
Europe/Asia/Australia/New Zealand 230V
Mains Power Inputs IEC C14
Fuse Compliment all Countries 4 - 10 amp fast blow H-Rated 5x20mm Rail Fuses
Fuse Compliment Mains 100vac Countries
1 - 2 amp slow blow H-rated 5x20mm
1 - 12 amp slow blow H-rated 5x20mm
120vac Countries
1 - 10 amp slow blow H-rated 5x20mm
230vac Countries
1 - 1.6 amp slow blow H-rated 5x20mm
1 - 5 amp slow blow H-rated 5x20mm
Accessories Included US (NEMA 5-15P) (all versions)
Schuko (CEE7/7) (230V version)
UK (BS 1363) (230V version)
Audio Inputs RCA (Unbalanced)
XLR (Balanced)
Speaker Outputs Signature 250 Gold plated copper binding posts (2 pair per channel)
Speaker Outputs Signature 300 Gold plated copper binding posts (2 pair)
Other DC Trigger Input
3.5mm 5-15VDC
Warranty 3 years parts and labor on unit
1 year on vacuum tube
Power Consumption
@Ready 75 Watts
@Idle 175 Watts
@Rated power 8Ω 850 Watts
@Rated power 4Ω 1600 Watts
Signal
Gain 30.5dB +/-0.5dB
Sensitivity for rated output power of 250 watts into 8Ω 1.3V
Noise 100-20KHz <-85dBV
Input impedance Signature 250 stereo Unbalanced 100KΩ
Balanced 200KΩ
Input impedance Signature 300 mono Unbalanced 50KΩ
Balanced 100KΩ
Output Impedance 50Hz, 2.8VRMS <0.1Ω
Frequency Response @2.8VRMS
10Hz – 20KHz +/- 0.1dB
10Hz – 200KHz +0.1/-3.0dB
THD&IM
1KHz, 1W/8Ω <0.01%
20-20KHz, 1W/8Ω <0.1%
1KHz, 200W/8Ω < 0.1% (120VAC Mains input)
1KHz, 400W/4Ω < 0.1% (120VAC Mains input)
Output Power
Both channels driven 120vac mains, 1kHz, 1% THD
8Ω 250W minimum
4Ω 500W minimum
2Ω Stable for musical transients
Signature 300 Mono Amplifier
Output Power
8Ω 300W minimum
4Ω 600W minimum
2Ω 1000W
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
