BHK Signature 600 Mono
| Unit Weight | 108 lbs [49 kg] |
| Unit Dimensions | 17.1” x 11.2” x 14” Chassis only. 17.5″ deep including connectors and handles |
| Shipping Weight | 120 lbs [55 kg] |
| Shipping Dimensions | 24”x 17” x 24” |
| Color Options | Black Silver |
| Voltage Options Factory set only |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
| Mains Power Inputs | IEC C14 |
| Fuse Compliment all Countries (internal) | 4 - 15A Fast Acting 5x20mm type F250V10AL |
| Fuse Compliment Mains (back panel) | 100vac Countries 1 - 2 amp time-lag H-rated 5x20mm 1 - 12.5 amp time-lag H-rated 5x20mm 120vac Countries 1 - 2 amp time-lag H-rated 5x20mm 1 - 10 amp time-lag H-rated 5x20mm 230vac Countries 1 - 1.6 amp time-lag H-rated 5x20mm 1 - 8 amp time-lag H-rated 5x20mm |
| Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
| Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
| Speaker Outputs | Gold plated copper binding posts (2 pair per channel) |
| Other | DC Trigger Input with pass through 3.5mm 5-15VDC |
| Warranty | 3 years parts and labor on unit 1 year on vacuum tube |
Power Consumption |
| @Ready | 75 Watts |
| @Idle | 225 Watts |
| @Rated power 8Ω | 950 Watts |
| @Rated power 4Ω | 1500 Watts |
Signal |
| Gain | 26.0dB/30.5dB +/-0.5dB selectable |
| Sensitivity for rated output power of 600 watts into 8Ω | 3.5V/2.1V |
| Noise | 100-20KHz <-100dBV |
| Input impedance | Single Ended 100KΩ Balanced 200KΩ |
| Output Impedance | <70mΩ (20-20KHz) |
| Frequency Response | @2.8VRMS 10Hz – 20KHz +/- 0.1dB 10Hz – 100KHz +0.1/-3.0dB |
THD & IM |
| 1KHz, 1W/8Ω | <0.002% |
| 20-20KHz, 1W/8Ω | <0.01% |
| 1KHz, 200W/8Ω | < 0.01% (120VAC Mains input) |
| 1KHz, 400W/4Ω | < 0.02% (120VAC Mains input) |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
| 8Ω | 600W minimum |
| 4Ω | 1000W minimum |
| 2Ω | Stable for musical transients |
BHK Mono 600 Power Amplifier Pair
Price is per pair.
Design
Application
Overview
Input Stage
Output stage
Features
18 key featuresZERO LOSS INPUT TUBE
POWERFUL MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
RCA SINGLE-ENDED INPUT
XLR "TRUE" BALANCED INPUT
600 WATTS PER CHANNEL 8Ω
1200 WATTS PER CHANNEL 4Ω
2000 WATTS PER CHANNEL 2Ω
-3dB > 200khz
< 0.1% THD 20Hz - 20kHz AT RATED POWER
DAMPING FACTOR = 700
FRONT PANEL STANDBY BUTTON
BALANCED INPUT TO OUTPUT
DUAL, COPPER, PLATED, OUTPUT BINDING POSTS
108 LBS.
INPUT 12 VOLT TRIGGER
FULLY PARALLELED INSIDE
EASY ACCESS FOR TUBES
Reviews
4 reviewsTom Martin reviews the PS Audio BHK 600 Power Amplifiers, details its brutish power supply, its vacuum tube rectification stage, and relays some of the history behind the designer, the late Bascom H. King.
Read full review →
Immediately noticeable from the first track, the BHK 600 Mono has an effortless, open, and large dynamic sound that is easy to notice.
Read full review →
With the BHK M600's prodigious power it should go without saying that this amp didn't once sound out of breath, no matter the task at hand. These heavyweight valve/solid-state hybrids will surely drive any speaker you might consider, and do so with total control and purity of performance. Installing them might require some labour, but their music-making is effortless
Read full review →
A major "oh shit" moment! Cranking up the title track on The Afghan Whigs Gentlemen is a major "Oh Shit" moment. I'm still getting used to the Peak Consult Sinfonias as the new reference speaker here, and they are a good, but slightly warm fit for the Pass Labs XA200.8s and Cardas Clear speaker cable that is my go to reference
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
