Factory Certified
Streaming · Network bridge
AirLens™
You've not yet heard how great streaming can sound.
$999 $1,999
Options
Join the waiting list
Factory Certified units come back in small numbers. Leave your email and we'll let you know when one is ready.
Buy or audition near you
All dealers
Factory Certified
Tested in Boulder by the people who built it
14-day in-home evaluation. One-year factory warranty when registered. Each unit is fully factory tested in Boulder; some may show light cosmetic blemishes.
Factory Certified units are already priced well below new, so they can't be combined with Trade-Up credit or other discounts.
Designed for streaming from Roon, Qobuz or Tidal into a DAC you own
  • Volume None. It feeds your DAC
  • Formats PCM to 352.8 kHz and quad-rate DSD
  • Output I²S and coax, to your DAC
  • Inputs Ethernet or Wi-Fi. Roon Ready, Tidal and Qobuz Connect
What reviewers say
The PS Audio AirLens is subjectively the best streamer I have tested; it isn’t even that close.
SSecrets of Home TheaterJim Clements, 2024
…the AirLens through Roon had the spark and clarity I was lacking from previous and comparative streaming attempts.
AAudiophiliaJesús González-Monreal, 2023
I thoroughly enjoyed my time with the PS Audio AirLens, which provided a gateway to noticeably higher performance.
FFuture AudiophileGreg Handy, 2024
Why choose it
Streaming, without the noise
Galvanic isolation means no electrical connection between your network and your DAC, and Digital Lens reclocking hands your DAC steady timing. Works with Roon, Tidal Connect and Qobuz Connect.
Where it fits
Eliminating the noisy USB to-computer connection and instead placing the PS Audio AirLens between your home network via Ethernet or WiFi will change forever the performance of streaming music. Once connected to any DAC, the AirLens interface will bring exceptional transparency, resolution, timbral realism, and wide dynamics to any D to A converter. Noise from any number of sources including your computer, long runs of Ethernet cable, EMI interference through WiFi, the system modem and router, all contribute to increased jitter and a general reduction of fidelity in the system.
Read more
Eliminating the noisy USB to-computer connection and instead placing the PS Audio AirLens between your home network via Ethernet or WiFi will change forever the performance of streaming music. Once connected to any DAC, the AirLens interface will bring exceptional transparency, resolution, timbral realism, and wide dynamics to any D to A converter. Noise from any number of sources including your computer, long runs of Ethernet cable, EMI interference through WiFi, the system modem and router, all contribute to increased jitter and a general reduction of fidelity in the system. Connecting your DAC via its coax or I2S inputs completely removes the haze and congestion caused by these noise sources.
Design
How it's built
Whether you stream network music through Roon, Audirvana, JRiver, Tidal Direct, Spotify, your NAS, or any DLNA-compatible server, you will introduce unwanted noise into your sensitive DAC. A USB connection to the computer is by far the noisiest method, followed by a close second via Ethernet or WiFi.
Read the full design story
Whether you stream network music through Roon, Audirvana, JRiver, Tidal Direct, Spotify, your NAS, or any DLNA-compatible server, you will introduce unwanted noise into your sensitive DAC. A USB connection to the computer is by far the noisiest method, followed by a close second via Ethernet or WiFi. What is needed to completely remove this injurious noise is the elimination of any electrical connection between the computer, its network, and your DAC. The PS Audio AirLens has both an input stage and a galvanically isolated reclocking output stage. The two are connected only "through the air." By using separate power supplies, there are no physical ground or signal connections, ensuring 100% isolation and noise-free delivery of perfect digital audio signals.
352.8 kHz
PCM
DSD256
native or DoP
Roon Ready
plus Tidal and Qobuz Connect
01
Galvanic Isolation
Galvanic isolation means the complete elimination of any physical electrical connection between input and output. Typically, a common power supply provides ground and power to both inputs and outputs.
Read more
Galvanic isolation means the complete elimination of any physical electrical connection between input and output. Typically, a common power supply provides ground and power to both inputs and outputs. Once a non-galvanically isolated device is connected to a noise source at its input, its shared ground passes the noise through a common ground to the output stage where the DAC is connected. The challenge with the AirLens was to design two fully isolated stages: input and output, and connect the digital audio signal between the two without any loss. To do this we incorporated a low-noise galvanically isolated DC-to-DC converter to feed power to the AirLens' output stage. We then deliver the received digital audio data to that clean output stage using only air as the interface. The results are nothing short of amazing. Finally, streaming music with all the noise and jitter-induced haze and congestion gone.
02
Digital Lens Technology
Digital audio signals rely upon critical stability in timing to sound their best. Relying upon the clock in your computer or the clock inside of a streaming interface is typically less than ideal.
Read more
Digital audio signals rely upon critical stability in timing to sound their best. Relying upon the clock in your computer or the clock inside of a streaming interface is typically less than ideal. As network musical data enters a computer or streaming interface there is no clock associated with the data. Once collected, the master clock must be added so that your DAC can function properly. Inside the AirLens is our famous Digital Lens technology. Based on a variable RAM buffer, the data is collected and stored before being sent out to the DAC by a high-precision, low-jitter fixed clock. This reclocking of the data coupled with the elimination of noise provides to your DAC the cleanest low jitter digital audio signal possible. The results are stunning. Suddenly, streamed music rivals that of local music from your transport. Experience the difference from the AirLens.
03
What You Can Expect
Whether you choose your streamed music through Roon, Audirvana, JRiver, Tidal Direct, Spotify, or any DLNA-compatible source (like your NAS), the addition of the PS Audio AirLens between the network and your DAC will set a new standard of musicality. Simply connect your network to the AirLens through Ethernet or WiFi, then your DAC to the AirLens through either coax (RCA) or I2S (via an HDMI cable) then sit back and be amazed.
Read more
Whether you choose your streamed music through Roon, Audirvana, JRiver, Tidal Direct, Spotify, or any DLNA-compatible source (like your NAS), the addition of the PS Audio AirLens between the network and your DAC will set a new standard of musicality. Simply connect your network to the AirLens through Ethernet or WiFi, then your DAC to the AirLens through either coax (RCA) or I2S (via an HDMI cable) then sit back and be amazed. The AirLens connects any DAC to the outside world via your home network and protects your sensitive DAC from any unwanted noise from cables, computers, and WiFi. The AirLens will handle PCM up to 384kHz, and DSD up to 256 (4X) in DoP or native. The world of streaming just took a major leap forward in sound quality. We cannot wait for you to experience all that streaming has to offer.
Features
At a glance
  • Network interface for streaming music
  • PCM up to 352.8khz
  • DSD to 256(4x)
  • Dop or native
  • Galvanically isolated input to output
  • Low jitter reclocker
  • Digital Lens output
  • Elimination of digital noise and hash
  • Rca coax output
  • I²s output
  • Roon ready
  • Dlna ready
  • Improves sound quality
  • Eliminates network and wifi noise
Specifications
Full specifications
General
Unit Weight4.8 lbs [2.2 kg]
Unit Dimensions10” x 7” x 1.5” [ 25.4cm x 17.8cm x 3.8cm]
Shipping Weight6.8 lbs [3.1 kg]
Shipping Dimensions5.8” x 13.6” x 11.6” [14.6 cm x 34.6 cm x 29.4 cm]
Color OptionsBlack, Silver
Voltage OptionsUniversal
Mains Power Input100-240VAC 50-60Hz
Power Consumption5W Typical/10W max
Accessories IncludedPower cord
Input10/100/1000 Ethernet or 2.4 & 5GHz WIFI
Audio Outputs12s, S/PDIF Coax
Features
Audio Interface• PCM: Up to 352.8kHz/32 • Native DSD up to DSD256 (I2S output) • DoP (DSD over PCM) up to DSD128 (Coax output)
Network Support• WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) • 10/100/1000 Ethernet
WiFi Setup• WPS
Connectivity• DLNA 1.5 & UPnP AV 1.0 Digital Media Renderer • Spotify Connect • Roon Ready • TIDAL Connect • Qobuz Connect • Dropbox (through Roon) • MQA
Compare
How it compares
512 DACStellarGold DACStellar DACAirLensThis one
Price$8,999$3,999$2,199$1,999
VolumeBuilt in, analog. Drives a power amp directlyBuilt in. A preamp is best for high-end systemsBuilt in, fixed or variableNone. It feeds your DAC
FormatsPCM and quad-rate DSDPCM to 768 kHz and quad-rate DSDPCM and double-rate DSDPCM to 352.8 kHz and quad-rate DSD
OutputBalanced XLR, Class ABalanced XLR, Class ABalanced XLR, Class AI²S and coax, to your DAC
InputsIncludes I²S for DSD directI²S, USB, AES/EBU and coaxIncludes I²S for DSD directEthernet or Wi-Fi. Roon Ready, Tidal and Qobuz Connect
Build your system
What it pairs with
Reviews
More reviews
I wish for my audio system to thrill me, not lull me to sleep.
I become excited about a product that moves my listening sessions into uncharted territory of performance, and the AirLens with the Mk2 were leading me onto new listening ground.
CConstantine Soo's Dagogo2024
Read the full review
JJim Clements, Secrets of Home Theater and High Fidelity2024
GGreg Handy, Future Audiophile2024
The new PS Audio AirLens streamer produces excellent sonic results at an affordable price.
LLawrence D. Devoe, MD, TheaterByte2023
The PS Audio AirLens is a great-sounding unit that just worked.
DDouglas Moore, The Sound Advocate2024
JJesús González-Monreal, Audiophilia2023
Read all 9 reviews
…the AirLens combined with the DirectStream DAC MK2 delivered a sound that was both engaging and insightful…
MMark Craven, Hi-Fi News2024
The soundstage was a that bit deeper, vocals were a tad clearer, effects easier to differentiate, and issues within recordings were better handled
FForum memberOwner · PS Audio forum · 2024
Read the full post
PS Audio AirLens HiFi Music Streamer is Too Good To Be True for Under 000
JJay's Iyagi (YouTube)2024
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Skip to product information
Silver
href="/products/airlens-refurbished?variant=48716543983906" class="link" >AirLens - Factory Certified
<b>The AirLens™ interface brings perfection to streaming</b>
Streaming audio via Roon or other services like Qobuz, Tidal, and Spotify offers millions of titles at the touch of a finger. Unfortunately, connecting your sensitive DAC to the noise generated by computers, routers, NAS, local networks, and modems via either WiFi or Ethernet cable is not a great-sounding solution to bringing high-performance audio into your listening environment. The PS Audio AirLens™ completely eliminates the problems of noise, jitter, and EMI influences through complete galvanic isolation and perfect reclocking of the digital audio signal. You’ve not yet heard how great streaming can sound until you experience audio through the AirLens.
Note:
Sale price  $999.00 Regular price  $1,999.00
Factory Certified 14-Day In-Home Evaluation Click for details
At home
Where it disappears into the music.
What Factory Certified means
These are PS Audio units that have come home to our factory in Boulder — trade-ins, demos, and returns — not off-the-shelf new production. Each one is fully tested on the same benches we use for new gear: performance, safety, and reliability before it ships again.
  • 14-day in-home evaluation — live with it in your own system before you decide.
  • One-year factory warranty from your purchase date when you register the serial (new products carry three years).
  • Honest cosmetics — function and measured performance meet factory standards; some units may show light blemishes.
Full Factory Certified warranty and evaluation terms
Streaming audio via Roon or other services like Qobuz Connect, Tidal, and Spotify offers millions of titles at the touch of a finger. Unfortunately, connecting your sensitive DAC to the noise generated by computers, routers, NAS, local networks, and modems via either WiFi or Ethernet cable is not a great-sounding solution to bringing high-performance audio into your listening environment. The PS Audio AirLens™ completely eliminates the problems of noise, jitter, and EMI influences through complete galvanic isolation and perfect reclocking of the digital audio signal. You’ve not yet heard how great streaming can sound until you experience audio through the AirLens.
Galvanic Isolation
What You Can Expect
What owners and reviewers say
Jim Clements, Secrets of Home Theater and High Fidelity · Read full review
Greg Handy, Future Audiophile · Read full review
Lawrence D. Devoe, MD, TheaterByte · Read full review
Douglas Moore, The Sound Advocate · Read full review
Jesús González-Monreal, Audiophilia · Read full review
Mark Craven, Hi-Fi News · Read full review
Mr. Underhill, Maverick Hi-Fi Forum · Read full review
I wish for my audio system to thrill me, not lull me to sleep. I become excited about a product that moves my listening sessions into uncharted territory of performance, and the AirLens with the Mk2 were leading me onto new listening ground.
Constantine Soo's Dagogo · Read full review
Jay's Iyagi (YouTube) · Read full review
This is not the 30-day new-product trial — it is the Factory Certified evaluation period. How it works, or read the full warranty and returns policy.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
14-day in-home evaluation $999.00
Add to cart
Call
TALK TO A HI-FI SPECIALIST
Design
Applications
Galvanic Isolation
What You Can Expect
Product Videos
Features
16 key features
NETWORK INTERFACE FOR STREAMING MUSIC
PCM UP TO 352.8kHz
DSD TO 256(4X)
DOP OR NATIVE
GALVANICALLY ISOLATED INPUT TO OUTPUT
LOW JITTER RECLOCKER
DIGITAL LENS OUTPUT
ELIMINATION OF DIGITAL NOISE AND HASH
RCA COAX OUTPUT
I²S OUTPUT
ROON READY
DLNA READY
IMPROVES SOUND QUALITY
ELIMINATES NETWORK AND WIFI NOISE
TIDAL CONNECT
QOBUZ CONNECT
Reviews
9 reviews
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Want to leave your own review?
Specifications
Technical details
General
Unit Weight 4.8 lbs [2.2 kg]
Unit Dimensions 10” x 7” x 1.5” [ 25.4cm x 17.8cm x 3.8cm]
Shipping Weight 6.8 lbs [3.1 kg]
Shipping Dimensions 5.8” x 13.6” x 11.6” [14.6 cm x 34.6 cm x 29.4 cm]
Color Options Black, Silver
Voltage Options Universal
Mains Power Input 100-240VAC 50-60Hz
Power Consumption 5W Typical/10W max
Accessories Included Power cord
Input 10/100/1000 Ethernet or 2.4 & 5GHz WIFI
Audio Outputs 12s, S/PDIF Coax
Features
Audio Interface • PCM: Up to 352.8kHz/32
Network Support • WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band)
WiFi Setup • WPS
Connectivity • DLNA 1.5 & UPnP AV 1.0 Digital Media Renderer
• Spotify Connect
• Roon Ready
• TIDAL Connect
• Qobuz Connect
• MQA
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
General
Features
WiFi Setup • WPS
• Spotify Connect
• Roon Ready
• TIDAL Connect
• Qobuz Connect
• MQA
Recommended products
