Amp classes
Prev Next
In the past few days we've covered a lot of ground learning about the various amplifier classes like A, AB, B which are the main amplification classes, referring mostly to how the output stages of the amplifiers use power: efficiently or inefficiently. We also covered Complimentary, Push Pull and Single Ended output stages.
There are others, such as Class H and T: H is a Class AB output stage with a variable power supply that goes up or down in stages depending on the size of the input signal. Class T is a marketing term used by TriPath to differentiate their Class D amps which have some unique feedback characteristics. I am sure there are more, but probably none very interesting.
Perhaps the most interesting of them all is Class D, sometimes known as a Digital Amplifier. As I have mentioned before, Class D is not digital it is, in fact, analog but in a very different form.
Traditional power amplifiers take a small input signal, make it bigger and then provide enough horsepower to drive your loudspeaker. To do this they are designed in two successive stages: the input voltage stage and the output current stage. The first stage of a power amplifier takes a small input signal and amplifies it typically 30 times: put one volt of music in and you get 30 volts of music out. Simple.
The second stage of a power amplifier takes the large voltage output of the first stage and adds current capabilities so that large voltage has enough power to drive a loudspeaker. Put 30 volts into this stage and get 30 volts out - the difference is this second stage can also deliver power - measured in watts, to the loudspeaker.
In a Class D amplifier we also have two stages, but the first stage is very different than a traditional power amplifier as is the second stage. In a very weird scenario the input stage compares the music to a reference signal, unrelated to the input, then feeds that information to the output stage which then connects all the watts in the amp's power supply up to the speaker - for varying amounts of time. This process is called PWM or Pulse Width Modulation.
Tomorrow we will make this strange and wonderful process make sense for you.
Back to blog
Paul McGowan
Founder & CEO
Never miss a post
Subscribe
Related Posts
