Copper Magazine · Issue 16 · A free PS Audio publication
Issue 16 FEATURED
Amplified & Equalized
Having generated a few milli- or micro-volts by our humble little cartridge, we now have to equalize by applying the inverse of the RIAA curve that was applied when the record was mastered, and then amplify the signal enough to drive our main amplifier.
Electronically (or even just electrically) , a phono stage is  very difficult  to engineer properly, which helps explain a veritable cornucopia of designs out there. Tubes or transistors,  op amps, head amps, SUTs, passive or active… it is a mind-boggling array!
Take a modest MM / moving magnet cartridge, with a quoted output of 5mv: our main amplifier really would like to see a minimum of 500mv, so our phono stage has to add gain at 100 times, at the same time adding the necessary RIAA curve. To further complicate matters, that curve is so severe that  it can wipe out the gain of an entire stage of the design.
Most designs, tube or transistor, use active circuits which use negative feedback.  I don’t want to get too technical, but some basics can be covered.  The cartridge signal is amplified by a circuit having very high gain, this may be two or three tubes, several transistors, or one or two Integrated Circuits (which is must be remembered can contain 40+ transistors in each).
Part of the high output of the preamplifier circuit is returned (fed back)  to the input of the preamplifier, and at the same time a small network of capacitors and resistors adjusts the level of feedback selectively at the bass, mid and treble frequencies to apply the RIAA equalisation curve. Less feedback in the bass, very high feedback in the treble. Feedback can also help reduce levels of distortion, which is no bad thing. But as the feedback is different at the bass and treble frequencies (more gain need for the bass frequencies) the amount of distortion also changes with frequency, which is not a good thing.
Generally speaking, transistors (including ICs, or integrated circuits) are not as linear as tubes, nor do they have as much gain per device. That’s why transistors are usually used with feedback to help counter these issues. There is also an argument that using any feedback can ‘flatten’ the sound, or make it less real. In High End tube circles, especially those using big fat DHT (directly heated triode) amps, feedback is generally sneered at!
One of the first RIAA circuits every printed, one by RCA, is a classic example of a no-feedback circuit, and one that has been ‘reinvented, time and time again, although it always really stays the same.  It uses a single tube per channel, but a tube that is actually a kind of Siamese twin, with a shared glass bulb, but with two little individual halves inside.  One half of the tube amplifies, and then the signal is fed through a small bunch of capacitors and resistors, which selectively equalise and apply the RIAA curve. This is then amplified again by the final half of the tube. With no feedback applied, the distortion is around 5% per stage. In addition, maximum gain cannot be made from the tubes used, and the first half will overload more easily in the treble, because the RIAA equalisation is providing it with a very low load.
Adding more tubes, and using cathode followers or SRPP (series regulated push-pull) principles, can help with this last problem, but not  with the distortion. SRPP uses both ‘halves’ of the tube as one, thus twice as many tubes are needed. The ultimate configuration of this kind of circuit uses an LCR filter; instead of the small resistors and capacitors, a series of inductors, capacitors, and resistors are matched and sealed in what looks like a transformer. The use of inductors can be seen as a benefit over just using resistors, but the costs are enormous. The simple capacitors and resistors of the basic circuit could cost as little as a few cents, but LCR RIAA filters cost a good few hundred bucks. Kouichi “Nobu” Shishido published such a circuit in the November, 1996 issue of the Japanese magazine MJ Audio  Technology , which was reprinted in Sound Practices magazine and became a defacto circuit.
There are of course lots of hybrid designs, mixing  feedback stages  with all or part of the RIAA done passively; confusingly, there are also ‘hybrids’ mixing tubes with solid state elements in active gain stages.
Personally, I use a tube unit which utilizes feedback. It uses the same Siamese tube RCA used, but set for higher gain, with feedback in which I invoke the RIAA curve. I am not alone, as such a configuration has been used by Stewart Hegeman, Marantz, Hafler, Dynaco, Fisher, Scott, Audio Research (early!) Conrad Johnson, Luxman, Croft Acoustics, and many others. Carefully built, it’s an excellent basis for design.
People do get bogged down in specs. Being anal-retentive about the RIAA curve is pretty irrelevant, given the variations in EQ used in mastering actual records. The more electronics you feed something through, the worse it gets, generally speaking. Amplifiers DO NOT make things better, they add gain, but always subtract ‘something’; thus, the more amplifiers, the more is lost. Keeping a circuit simple can aid fidelity, but make it too crude, and it can be counterproductive, as it will tend to create more distortion.
All this is fine for MM cartridges, but what about moving coil? These have outputs one tenth to one fiftieth  that of a moving magnet. To increase gain, it is either necessary to add an extra active stage, use a transformer, or in the case of a real budget phono stage cheat, reduce the negative feedback to create more gain (as well as more noise and distortion!).
Phono stages already create more electrical noise than most other parts of your hi-fi system, but to boost the MC signal it becomes even harder. Using a tube as a kind of pre-pre-amp has been done many times, but they are nearly always noisy.  Using a select mix of FET and transistors is probably the best active compromise, and the use of a poor quality IC is best avoided.
Step up transformers can be one of the best ways of achieving gain; even these introduce distortion, and good ones are scary expensive.  To maintain bandwidth complex winding techniques are used, with high grades of wire. To stop the transformer picking up other unwanted signals (think 0.001v signal to 120.000V mains supply) mu-metal and extensive magnetic shielding is needed.
Personally, I prefer transformers over other step-up devices in a high-end set up. But down on a budget, the vast majority of phono stages are purely active. To be honest, this is probably a lot better than using poor-quality transformers.
There are so many phono stages on the market now. There are hundreds of the little (and not so little) blighters. If on a tight budget it’s impossible to avoid the IC-based ones. But look at the wall-wart power supply, make sure it’s at least 18V or more, and it will at least not overload. And as far as I’m concerned , try to upgrade to tube ASAP!
More from Issue 16
View All Articles in Issue 16
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
