Working together
Working together
We’ve all been tempted by numbers. Lower noise, higher damping factor, vanishingly low distortion. It’s easy to assume that if each piece of gear performs well on its own, the system as a whole will do the same.
But often, it doesn’t work that way.
High-end 2-channel audio isn’t just about individual performance—it’s about how everything works together.
A preamp might sound fantastic into one amp but flat into another. A revealing speaker might blossom with a warm, full-bodied amp, and sound thin with a leaner one. Cables, too—especially between source and preamp—can subtly shift the tonal balance.
Synergy isn’t magic. It’s matching. Voltage levels, impedance relationships, gain, bandwidth, phase—these are all part of it. But mostly it's voicing. Feel. That harder-to-pin-down quality where everything just clicks.
When it’s right, you know. The system breathes as a whole. Nothing jumps out, nothing holds back. The stage opens up, the timing locks in…
…and you stop thinking about the gear.
Working together
Working together
