Winners and losers
Winners and losers
The biggest single variable in your audio system isn't your gear. It's the room you put it in.
Change the room and you change everything.
We've covered this many times before, but I think it's always worth revisiting.
Consider the same electronics, same speakers, same cables, deployed in two rooms in two different cities. One sounds wonderful. The other sounds wrong. Setup? Sure but let's not ignore the room, which is part of the system.
Below roughly 200 Hz, what we hear isn't really the speaker anymore — it's the speaker driving a small, enclosed three-dimensional resonator that we're sitting inside of. Room dimensions decide which bass notes pile up, which ones cancel, and where in the room those peaks and nulls land. Two rooms with different proportions will give you completely different bass with identical speakers in identical positions relative to the walls. Not subtly different. Often dramatically different.
Above 200 Hz the rules change again. Early reflections off side walls, the floor, the ceiling, and the wall behind the speakers all arrive at your ears within a few milliseconds of the direct sound. Your brain folds those reflections into what it interprets as imaging, depth, and tonal balance — and it does so without ever announcing the work it's doing. A bright room with bare walls smears the picture. A heavily damped room can suck the life out of it. Most of us are somewhere in between, and the differences between two such rooms can be enormous.
The practical takeaway is what I keep coming back to with every member of our community who'll listen. Position your speakers where they image best — that's the first job and you don't compromise it.
Then bring in a subwoofer placed independently to fix what the room is doing to your bass, because moving the main speakers to chase low end almost always wrecks the soundstage you just earned.
Treat the worst reflection points if you can.
Do nothing if you can't.
Understand that the room has already cast its vote before your amplifier sends a single note, and that vote counts more than any cable or upgrade you'll ever buy.
The gear gets all the credit, but the room writes the script.
Winners and losers
Winners and losers
