Why less isn't always more
We often repeat the mantra that less in the signal path is more. On the surface, it makes perfect sense. Every component, every connection, every circuit element has the potential to add distortion, noise, or coloration. The shortest and simplest path should be the most transparent. And yet, in practice, removing the preamplifier from a system often diminishes the music rather than improving it.
This is the paradox of the preamp.
A preamplifier’s basic function is volume control and source selection. In a direct system, one might assume that a DAC or phono stage with a built-in level control could feed an amplifier directly, eliminating what appears to be an unnecessary stage. Many of us have tried it, and on first listen, the results can seem promising. The sound may feel cleaner, more immediate, as if a veil has been lifted. But after longer listening, we often notice what’s missing: dynamics flatten, tonal richness thins, and imaging loses stability.
The music sounds less alive.
Why does this happen? A well-designed preamplifier does far more than pass along a signal. It provides proper impedance matching between source and amplifier, ensuring that neither struggles to deliver current or voltage. It buffers the signal, giving the power amplifier a strong, stable input to work with. And it preserves low-level detail across a wide range of volumes, something that many digital volume controls in DACs struggle to maintain.
Without those functions, subtle musical information is often lost.
There’s also the question of drive. Power amplifiers, especially those with lower input sensitivity, benefit from being fed by a component capable of delivering current with authority. A passive attenuator or underpowered source can leave an amplifier sounding thin or undernourished. A robust preamp, on the other hand, energizes the chain, giving the amplifier the conditions it needs to perform at its best.
As admitted lovers of high-end audio, we’re trained to be skeptical of complexity, and rightly so. But a preamplifier, when done well, is not a liability—it’s an enabler. It allows the system to breathe, to preserve dynamics, and to maintain musical coherence from the quietest passage to the loudest climax. Far from being an obstacle, it can be the very component that holds the entire chain together.
The paradox remains: less is more, except when more gives us back what was missing. In the case of the preamplifier, adding a carefully designed stage often results in subtraction of exactly what we don’t want—grain, instability, and loss of life.
What we gain is musical integrity, and that is always worth the extra step.
