What's Watt?
What's Watt?
A 50-watt amp might sound great—until the music asks for 51.
Watts don’t tell you how good an amp sounds. But they do tell you what kind of speaker you can pair it with, and how much headroom you have before things start falling apart. And make no mistake—headroom matters. Without it, you're walking a fine line between effortless and straining.
Music isn’t constant. Peaks can hit 10 to 20 decibels above the average level. That means your amp needs four to ten times the continuous power just to avoid clipping on dynamic transients (and sonically worse, compression as the amp nears its limits). If you're cruising at 5 watts on average, peaks might spike to 50. And if you're listening loud—or playing dynamic recordings—that demand rises fast.
And then, of course, there's the proverbial “turn it up to 11” moment. We’ve all been there. The track hits just right, and suddenly you're past the point your amp was designed for.
Headroom is what lets an amplifier breathe. It’s what keeps dynamics intact, preserves spatial cues, and prevents compression from sneaking in when things get intense. Even if you never use the full rated power, knowing it's there means your amp won’t flinch when the music surges.
That’s why more watts—clean, stable, well-designed watts—are never a bad thing. Because when it comes to musical realism, margin matters.
What's Watt?
What's Watt?
