We won't get fooled again
One of the most common traps we audiophiles fall into is confusing clarity with brightness. When you first swap in a new cable, DAC, or pair of speakers and hear more detail, it’s easy to assume that extra energy up top means more resolution. Sometimes it does. But often, it’s just more treble.
The hard truth is that our brains are wired to notice high-frequency content. When something’s louder in that range—even slightly—it can seem more open, more airy, more detailed. But after a while, the illusion wears off. You start to notice that cymbals sound a little etched. Vocals get shouty.
Listening becomes fatiguing.
You've been fooled into the brightness trap.
True clarity doesn’t come from tilted-up treble. It comes from low noise, clean power, low jitter, and time-aligned transducers. When everything is right, the detail is just there—not hyped, not harsh, not shouting for attention.
It simply exists in space, as it does in life.
That’s why the first few minutes with a new piece of gear aren’t always the best test. Sometimes the real measure of fidelity isn’t how it grabs your ear—but how long you want to keep listening.
