Toe in and out
Toe in and out
Ask a room full of audiophiles how much toe-in to use, and you’ll get a dozen different answers. Some people like their speakers pointed right at them. Others prefer them straight ahead. But here’s the truth: the amount of toe-in your speakers need tells you a lot about how well they’re designed.
When a speaker has flat on-axis response but rolls off sharply as you move off axis, you’re forced to toe them in. That’s the only way to hear a balanced frequency spectrum. But if the off-axis response is smooth and matches the on-axis curve, you suddenly have options. You can toe them in, or leave them facing straight ahead—and the tonal balance doesn’t fall apart.
This matters because the sound we perceive isn’t just the direct wave hitting our ears. It’s a blend of that and the room’s contribution. And if that reflected energy is uneven, the illusion collapses. Imaging gets soft, the stage narrows, and you find yourself constantly adjusting your head to stay in the sweet spot.
That’s why we design the aspen speakers to work both ways. You can point them straight out into the room and still get a wide, stable stage. It’s not about feeding the room with energy—it’s about preserving the information your brain needs to hear space.
Toe-in becomes a choice, not a requirement. And that’s a sign of a speaker that’s doing its job.
Toe in and out
Toe in and out
