The battle
The battle
You can’t win an argument with a room. But you can learn how to make peace with it.
Every audiophile hits this wall at some point (pun intended). You upgrade the gear, optimize the setup, swap cables, tubes, fuses—and still something’s off. The bass is bloated. The image won’t lock in. The highs are harsh. That’s when it hits you: it’s not the gear. It’s the room. Or the setup. Or both.
But let's focus on just the room.
Rooms are sneaky. They don’t just color the sound—they shape it. Reinforce it. Cancel it. A 60Hz standing wave doesn’t care how much you paid for your loudspeakers.
And yet, most of us ignore the room far too long. I know I did. Back in the early days, I figured a better preamp or a different speaker would fix the problem. And without question it helped. But the real transformation came when I started treating the room as part of the system.
You don’t need to make it look like a studio. But strategic treatment—bass traps, diffusers, even good furniture placement—can change everything. Suddenly the imaging snaps into place. The bass tightens up. The music breathes.
Shameless plug. Grab a copy of The Listening Room.
The best gear in the world can’t fix a room that’s fighting you. But when the room starts working with the system instead of against it? That’s when the magic shows up.
You don’t have to win the argument. You just have to listen—and let the room have its say.
The battle
The battle
