Small works too
Small works too
There’s nothing quite like the sound of a full-range loudspeaker. A proper pair of floorstanders—like the Aspen FR30s or FR20s—can deliver scale, weight, and dimensionality that just wraps you in the music. When they’re set up right, you don’t just hear the orchestra—you sit in the hall with them.
But the truth is, big speakers don’t work for everyone. Whether it’s the room, the layout, or budget, not every space can accommodate something that size.
Which is why we built the Aspen FR5.
We took the same design philosophy—fast planar magnetic drivers, flat off-axis response, carefully integrated bass alignment—and distilled it into a smaller, room-friendly form. The FR5 may not tower over you, but it absolutely fills the room. It throws a wide, deep soundstage, locks in imaging, and delivers the kind of tonal balance you usually only get from something much bigger.
And when you turn the lights down, close your eyes, and hit play, you might just forget they’re small at all.
Because great sound isn’t about size—it’s about honesty. And the FR5s are some of the most honest speakers we’ve ever built.
Small works too
Small works too
