Shared spaces
Shared spaces
Most of us audiophiles do not have a dedicated listening room, and that is perfectly fine.
The fantasy is a purpose-built space with no windows, optimized dimensions, strategic acoustic treatment, and a single chair positioned at the exact apex of an equilateral triangle with the speakers. The reality for most of us is a living room that also serves as a home theater, a family gathering spot, and occasionally a dining area. Furniture is where it needs to be for daily life, not for optimal soundstage. The speakers sit where they fit, not where the math says they should go.
I have had both kinds of rooms over the years. Our reference Listening Lab at PS Audio is tuned and treated and wonderful. But at home, my system lives in a space I share with Terri. The couch is not at the perfect distance. The FR5s are spaced apart a specific distance—not because it's optimal but because that's how wide the cabinet is. There are bookshelves and windows and all the compromises that come with a real house occupied by real people. And you know what? It still sounds great, because the fundamentals matter more than perfection.
If you are working with a shared space, focus on the things that make the biggest difference without turning your living room into a recording studio. Get the speakers away from the back wall by at least a foot or two if you can manage it. Upgrade to speakers that have wide and flat enough dispersion they don't care so much about placement. Make sure nothing is blocking the space between the speakers where the center image forms. A rug on a hard floor between you and the speakers helps more than you might expect. These basic moves cost nothing and can transform the sound.
The psychological part matters too. When I sit down to listen seriously, I am not doing anything else. The television is off. The phone is put away. That intentional focus does more for the listening experience than any room treatment ever could. A shared room with a focused listener will outperform a perfect room with a distracted one every single time.
Do not let the perfect be the enemy of the good. The fact that you care enough to set up a decent system in whatever room you have puts you ahead of most people on the planet. The music does not care whether your room has a dedicated circuit and bass traps in every corner. It just needs two speakers, an engaged pair of ears, and the willingness to sit still and listen.
Shared spaces
Shared spaces
