Shape matters
Shape matters
Every loudspeaker driver is a compromise between physics and the art of what sounds right.
I have been staring at speaker cones and films for over fifty years, and I still find it fascinating how something as seemingly simple as a cone's geometry can transform the way music reaches your ears. From concave to convex, flat to wildly sculpted, the driver profile is never arbitrary. It is one of the most consequential decisions a speaker engineer makes, and it affects everything from dispersion to distortion to how natural a voice sounds in your listening room.
The reason shape matters comes down to how a cone breaks up as it reproduces sound. A perfectly rigid cone would behave as a pure piston, moving in and out uniformly across its entire surface. In reality, no material is perfectly rigid. As frequencies climb, the cone begins to flex, and different areas start moving independently. This is called cone breakup, and it introduces distortion and coloration that can make vocals sound nasal, harsh, or boxy. The geometry of the cone determines where in the frequency range this breakup begins and how severe its effects are on the music.
A concave cone tends to be stiffer for its weight, which pushes breakup modes higher in frequency where they may fall outside the driver's operating range entirely. A flat or convex profile, like we use in our Aspen series, distributes mechanical energy differently and can offer a wider, more even dispersion pattern off axis. Chris Brunhaver spent years experimenting with driver geometry when designing our Aspen loudspeakers. His approach was to use planar magnetic midrange drivers that avoid traditional cone breakup altogether by driving a flat diaphragm uniformly across its surface. The result is a midrange that sounds open, immediate, and free from the boxy colorations you hear with many conventional cone drivers.
Some manufacturers use uniquely sculpted cone shapes as much for visual branding as for acoustics. That is perfectly fine as long as the engineering backs up the aesthetics. What matters is not the visual drama of the cone but its measured behavior under real-world operating conditions. A beautiful cone that breaks up at two kilohertz is going to sound worse than an ugly one that stays composed to five kilohertz. The best speaker designers I know pick the geometry that serves the crossover, the cabinet, and ultimately the listener rather than the brochure photographer.
If there is a takeaway here, it is this: do not judge a loudspeaker by the shape of its drivers alone. Listen to it. A well-designed midrange, regardless of whether it looks exotic or completely ordinary, will get out of the way and let you hear the recording.
The cone's job is to disappear, and the clever engineering that makes that happen is invisible from the outside. Next time you are auditioning speakers, close your eyes and let your ears make the call.
Shape matters
Shape matters
