Heavy Lifting
Heavy Lifting
Speakers are heavy, Sometimes really heavy.
Why?
Most of the weight in a well-built speaker comes from the cabinet itself—thick panels of MDF (Medium Density Fiberboard), HDF (High density same thing), or in some cases layered composites designed to resist vibration. The drivers add some, and the crossover components (those big inductors and capacitors inside) contribute a few more pounds. But the enclosure is where the real mass lives.
And that mass matters.
When a woofer pushes air forward, Newton's third law pushes back against the cabinet with equal force. If the cabinet is light or flimsy, it flexes and vibrates, turning itself into an unwanted sound source. You end up hearing the box as much as the music.
A heavy, well-braced cabinet resists that energy. The driver does its job, the enclosure stays still, and the sound comes from the drivers alone—which is exactly what you want.
This is why our Aspen speakers are substantial. The FR30, for example, uses an elaborate internal bracing structure. It's not heavy for the sake of being heavy. It's heavy because controlling cabinet resonance is one of the most important things a speaker designer can do.
There's a simple test. Knock on the side of a speaker cabinet with your knuckle. If it rings like a drum, that ringing is coloring everything you hear. If it sounds dead and inert—just a dull thud—it's often a sign that someone cared about what you'd hear.
Heavy Lifting
Heavy Lifting
Why?
