Going low
Going low
We usually talk about impedance when matching sources to loads—like making sure your preamp and amp play nicely together, or that a phono cartridge is loaded correctly. But one of the most overlooked areas where impedance matters is the AC power line itself.
Yes, I know, it's a constant refrain from me but I gotta tell you, so many folks just don't seem to get it that I am going to keep plugging away in the hopes of one by one bringing people into the fold.
The AC wall outlet in your home isn’t just a steady 120 volts feeding your gear. It’s a dynamic, shared supply whose impedance fluctuates with every appliance, dimmer switch, or fridge compressor on the circuit. Worse, it can responds to your audio system’s demands—especially when you're listening at higher volumes or with dynamic material—by sagging and modulating with the music.
Hint: that's not good and passive power conditioners of any type make this worse.
That’s not just theory. When your power amplifier suddenly demands current for a bass transient or big orchestral hit, and the line impedance is high, the voltage can momentarily dip. That means your gear is literally not getting what it needs when it needs it most. And that sag translates directly into lost dynamics, blurred timing, and compromised performance.
That’s why we build Power Plants as active regenerators. They don’t just clean the AC—they rebuild it. Internally, a Power Plant takes in the raw AC, converts it to DC, and then generates a brand-new, ultra-low-impedance AC sine wave in real time. It holds the voltage steady—even under heavy draw—and presents a solid, unflinching power source to your system. No dips, no modulation, no variability.
It’s like replacing a garden hose with a pressurized fire hydrant. Same connection. Entirely different result.
So yes, impedance matching between components is important. But don’t forget the biggest connection in your system: the wall. If that’s not solid, nothing else will be either.
Going low
Going low
