Forgotten surfaces
Forgotten surfaces
We count the walls but rarely the floor or ceiling.
Most audiophiles, when tuning their rooms, focus on the obvious: side walls and the rear wall behind the speakers. These surfaces cause early reflections that smear imaging and collapse the soundstage, so we treat them with absorbers or diffusers. But what about the horizontal boundaries above and below us? The floor and ceiling contribute just as much to the room’s sonic fingerprint, yet they’re often ignored.
We take them for granted.
I learned this the hard way in my first serious listening room. I had the walls dialed in—carefully measured toe-in, first reflection panels, even bass traps in the corners. Yet something was off. Voices hovered at the correct height, but cymbals smeared upward, and the bass lacked definition. It wasn’t until I looked overhead that I saw the problem: a hard, untreated ceiling reflecting energy straight back to the listening position.
Addressing that ceiling transformed the room. A few diffusers above the listening seat broke up reflections, while a rug beneath the speakers tamed floor bounce. Suddenly the midrange snapped into focus and the treble softened into a natural sheen. I hadn’t changed a single component—only respected the boundaries above and below me.
Next time you tune a system, look up and down, not just around. The floor and ceiling are partners in the sound. Treat them with the same respect as the walls, and the music will reward you.
Forgotten surfaces
Forgotten surfaces
