Expensive mistakes
Expensive mistakes
The most expensive way to build an audio system is to ignore synergy.
I've watched people spend serious money on components that don't work well together — an amplifier that can't keep up with the loudspeaker's voicing, a source component that's out of step with the rest of the chain, speakers that focus on all the wrong things.
If you don't have a favorite trusted brand to fall back on, then make sure you're able to listen at home for an extended period of time. A single demo at a dealer is valuable but it's not in your room and it's likely not with all your cables, setup, and gear.
But mostly, it's not in your room.
Most systems are limited more by their environment than by their components.
When you do need to upgrade, do it one component at a time. Live with the change for a while. Let your ears recalibrate. This is the only way to learn what your system actually responds to — and what makes no difference in your particular room with your particular speakers. It's slower than buying everything at once, but it's how you build real knowledge about what you're listening to.
The goal isn't a system that looks impressive on paper.
The goal is a system that makes you want to listen every night.
That's the one worth building.
Expensive mistakes
Expensive mistakes
