Dynamics!
Dynamics!
A system that compresses dynamics (and most do to some extent) doesn't just reduce loudness contrast — it removes the emotional impact from the music itself.
Dynamic range is the difference between the quietest and loudest moments in a recording. In live performance — a symphony orchestra, a jazz trio, a rock band at full intensity — that range is enormous. A violin at pianissimo might register around 35 decibels. The same orchestra at full fortissimo can exceed 100. That swing is a fundamental part of what makes live music feel physically present and emotionally alive in a way that even the best recording only partially captures. When a playback system compresses that range, the quiet passages get pushed up, the loud passages get pulled back, and the music becomes easier to ignore. Nothing startles. Nothing demands attention.
It sounds fine and feels like nothing.
Transient response is where you hear dynamic performance most clearly. A snare drum hit, a piano struck hard at the top of the register, a plucked upright bass — these events happen on the order of milliseconds. The system has to track the initial attack and follow it faithfully through the decay without softening the leading edge or adding blur. When a system handles transients cleanly, percussion sounds immediate, physical, and precise. When it doesn't, drums can sound like they're behind a pillow — the impact is technically present but the shock of it is gone, and with it goes the sense that music is actually happening.
Setup decisions feed into this more than most people realize. A speaker placed too close to the rear wall has its bass blurred by early reflections, which destroys transient definition — you can no longer clearly hear where a bass impulse starts and ends. The system's dynamic performance is partly a function of the space it lives in, not just the electronics. Our ears are more sensitive to dynamics than to almost any other acoustic variable, because dynamics are how we gauge scale, distance, and emotional intensity in the real world.
A system that gets this right doesn't just sound technically impressive.
It sounds like music.
Dynamics!
Dynamics!
