It's not a DSD world .... yet
In my opinion the future of all high resolution capable DACS is DSD. As mentioned earlier, most modern DACS are already converting PCM to DSD internally anyway, even many low cost USB only DACS that handle 192kHz/24 bits are Delta Sigma converters (at their hearts) and thus the architecture used is essentially that of DSD.
So one might ask why not start with DSD in the first place? Why convert from PCM to DSD when a pure DSD stream would make more sense? There are a number of good reasons why this hasn't yet happened more. Certainly there's an increase in DSD downloads available; for which you need a DSD capable DAC to play them. There are also a few original PCM recordings that have been converted to DSD - a practice I find loathsome at best, certainly not on the up and up at the least. An original DSD recording is one thing, converted analog to DSD is a great practice, converting original PCM to DSD and calling it "DSD" is not kosher IMHO.
Now let's understand DSD isn't all that friendly to recording engineers and studios. For one thing, you cannot edit DSD. You cannot digitally EQ DSD. When a recording studio wants to make edits or EQ the raw data they must first convert it to PCM, edit it, then convert it back to DSD. So that's a problem - but it turns out this is ok if you start with DSD, go to PCM and then back again.
Modern recording equipment that can handle DSD, like the Sonoma workstation used by our friends Gus Skinas and Cookie Marenco, can go from DSD to PCM and back again with nary a hitch in the get along. There doesn't seem to be a way to go from an original PCM recording to DSD and gain any of the advantages of DSD (which kind of makes sense), but going from DSD to PCM and back again is apparently ok. But it's not recordings or media I am really focusing on. No, it is DAC architecture.
Modern DACS, for the foreseeable future, will have to include a PCM to DSD converter. The trick to building superior DACS, I believe, will be to base the newest generation of DACS around DSD centric engines with PCM converters tacked on, as opposed to PCM centric architectures using a DSD Delta Sigma converter tacked onto the back. In fact, if you remember our post Lost my bits, I posted a block diagram of the Wolfson DAC chip we (and many others) use in the PWD. There you can see a PCM centric DAC with the capability of a DSD input. This describes 99% of the available chip sets out there for audio designers today. No effort has been put into manipulating the volume in DSD, or anything else other than just bypassing the PCM converter and giving designers a direct shot into the Delta Sigma modulator section.
So the current crop of the very best DAC chipsets available are what I would think of as generational hybrids based on the reality of a PCM based audio/music industry. There's big changes ahead in that field - of this I can speak on a personal experience basis. The future's bright indeed.
Let's attempt tomorrow to explain how a 1-bit DAC works.
