High-end audio has always had its two warring factions.
On one side, the measurementists: if the numbers are right, the sound is right. Distortion below the noise floor, ruler-flat frequency response, done. Listening tests are subjective and therefore suspect.
On the other side, the subjectivists: measurements are nice but not relevant. The ear is the only instrument that matters. Some of the best-measuring amplifiers sound sterile and lifeless, and some of the worst-measuring ones make you forget to go to bed.
Both camps have a point, which is probably why they argue so hard.
The gap between them has started to remind me of the political divide—two sides so far apart that the conversation has stopped being about finding truth and started being about winning. Each dismisses the other's entire framework before anyone plays a note.
But there's a third group that gets less forum airtime. We believe measurements matter—deeply—when they translate into musical magic. The goal isn't to win a benchmark. The goal is to build something that hooks the listener so completely they forget to check the time.
The measurements are the road. The music is the destination.
A perfectly engineered road that leads nowhere is just pavement.
