Burning up
Burning up
The idea that audio components need hours of use before settling into their best sound is one of the most debated topics in our community — and the skeptics are missing something important.
The burn-in debate runs predictably. Naysayers claim it's confirmation bias: you expect improvement after a hundred hours, so you hear it. Those of us who have heard it wouldn't think to deny its benefits. The debate rages on, but perhaps it's helpful to look at a few of the facts.
Electronic components change with use.
Capacitors are often the most significant factor. A new capacitor has a dielectric — the insulating material between its plates — that hasn't been subjected to sustained electric field stress. Under normal operating conditions, the dielectric polarizes and its characteristics settle measurably: capacitance value, dissipation factor, and equivalent series resistance all shift slightly during the first hours of use before stabilizing. In a circuit built to close tolerances, those shifts matter. Speaker drivers can be even more dramatic. A new woofer's surround and spider come from the factory relatively stiff and need mechanical working to reach their designed compliance — a new speaker's bass can sound tight and lean for the first ten to twenty hours, then open up as the suspension settles. You can measure this: the resonant frequency shifts downward.
It's a physical change, not an expectation.
The practical takeaway is simple. When new equipment arrives, give it time before drawing conclusions. Let the capacitors form, let the drivers settle, let the whole chain find its character — most equipment gets there somewhere between 50 and 200 hours.
A first impression after ten minutes out of the box tells you almost nothing.
If it sounds good early, hold on. It usually gets better.
Burning up
Burning up
