Big is better
Big is better
More watts does not mean louder music, but it almost always means better music.
This confuses people, and I understand why. If you have a twenty-watt amplifier and a two-hundred-watt amplifier, and you set them both to the same listening level on the same speakers, they are delivering the same voltage and the same current at that moment. At normal listening levels, even a modest amplifier is coasting along using a fraction of its rated power. So why would the bigger amplifier sound any different if it is barely breaking a sweat?
Headroom, and it changes everything.
Music is not a steady-state signal. It is an enormously dynamic waveform with peaks that can be ten to twenty decibels above the average level. A song that averages one watt of power can demand a hundred watts on a transient peak that lasts a fraction of a second. If your amplifier cannot deliver that peak cleanly, it sounds strained, compressed, unhappy.
For most listeners with typical modern speakers, I recommend more power than you think you need. Not because you will play louder, but because your amplifier will spend its life in the effortless middle of its operating range rather than straining at the edges. That ease translates directly into a more relaxed, dynamic, and spatially convincing listening experience.
The amplifier with reserves to spare sounds like it is not even trying, and that effortlessness is one of the hallmarks of great sound.
Big is better
Big is better
