Band Aids
Band Aids
EQ in a music system is a Band-Aid. Sometimes a Band-Aid is what you need. Most of the time, the wound is somewhere else.
A lot of HiFi Family members reach for EQ first when something sounds wrong — bass is too boomy, treble too bright, voices too thick. The instinct is reasonable, and the result is almost always disappointing. EQ in the system signal chain costs you something real. Phase shift around the bands you corrected. Extra circuitry the signal has to pass through.
"Fix it in pre" is the rule we live by at Octave Records (thanks, Seth!). Get the recording right at the source so you don't have to compensate for it later, because every layer of compensation costs you something.
The same principle applies to building a music system. The right order is fix the room first — placement, basic treatment, subwoofer integration where appropriate. Then look at the gear itself. The wrong speaker for the room can't be EQ'd into rightness, and the wrong amplifier for the speaker can't be filtered into agreement.
Where EQ genuinely shines is somewhere completely different — at the track and album level. Some recordings are mastered too bright, others too dark, others too compressed. A selective adjustment that lives with that one album, applied automatically every time it plays, can rescue a flawed master without imposing anything on the rest of your library. That's not a Band-Aid. That's a tool.
The system stays clean. The music gets better.
This is exactly what I am activating in an upcoming Maestro update at www.maestromusic.app. The system is called Prism — one of the coolest DSP implementations in the world — and it operates on a track or album basis with no additional circuitry in the signal path and no fidelity penalty.
The reason folks use Maestro in the first place is the sound quality—you've not heard streaming or your local library until you've heard it played through Maestro. Prism preserves that and gives us a surgical way to deal with problem masters without ever touching the system's voice.
System EQ is a Band-Aid. Track EQ is a tool. The trick is knowing which one you actually need.
Band Aids
Band Aids
