Applause please
Applause please
Two amplifiers can drive the same speakers in the same room and produce wildly different soundstages.
The difference isn't power. It's character.
Anyone who's auditioned a few power amps in the same system has run into this. Same speakers, same room, same source — and yet the soundstage between two amps can look completely different. One pushes the music wall to wall and a few feet deep into the room behind the speakers. Another collapses the same recording into a flat curtain stretched between the cabinets. The difference isn't power and it isn't always price. The answer lives in one of the more interesting corners of amplifier design that doesn't get talked about enough in our HiFi Family.
Soundstage width and depth are constructed by your brain from extremely small inter-channel differences in amplitude, timing, and phase. Any amplifier that smears those differences — whether through poor low-level linearity, less than lightning fast transient response, and distortion that quickly rises with frequency — narrows the stage. The brain just doesn't get enough clean information to build a wide, deep picture, so it defaults to placing everything closer to the speakers.
The other factor is how the amplifier controls the speaker. An amp that grips the driver firmly through transients keeps the leading edges of notes coherent. An amp that lets the driver coast a little — common with low damping factor designs or insufficient current at high frequencies — smears those transients enough that the brain can't quite pin down where the sound came from. The soundstage gets fuzzy. Images broaden in a way that's superficially spacious but lacks the believable solidity of a really well-defined image.
We use state of the art measuring gear when designing our products: Klippel for speaker measurement and Audio Precision for electronics. They tell us almost everything. But the last bit of what makes a great-sounding amp is the synergy between topology, feedback architecture, components, and power supply design — and the only instrument capable of judging that final result is a trained pair of ears.
The stage isn't a feature you add to an amplifier.
It's what's left when you stop ruining it.
Applause please
Applause please
