A hard truth
A hard truth
There is no full-range system without a subwoofer.
And it’s not because full-range speakers can’t produce bass. They absolutely can. Our Aspen series, for example, delivers deep, articulate low frequencies with authority. The issue isn’t whether a well-designed speaker can reach down low. It’s whether the room will let it do so properly.
The room simply won't allow that.
Where you position speakers for the best imaging—proper center fill, depth, and a stable soundstage—is almost never where the room supports smooth, even bass response. The locations that produce the most coherent three-dimensional image often excite room modes in ways that exaggerate or cancel low frequencies. You end up compromising either imaging or bass uniformity. And that’s a trade-off we don’t have to accept.
The lowest octave, from roughly 20Hz to 40Hz, carries the foundation of music. It’s the weight behind a piano’s left hand, the physical impact of a kick drum, the sense of air and space in a recording venue. Even when a speaker measures flat to those frequencies, the room dominates what we actually hear. Peaks, nulls, and standing waves reshape the response in ways no specification sheet can predict.
A properly integrated subwoofer solves this. It allows the main speakers to be positioned for imaging and soundstage precision, while the subwoofer can be placed where the room supports the smoothest low-frequency response. When we developed the Foundry F12, the goal wasn’t exaggerated bass or home theater theatrics. It was speed, pitch definition, and seamless integration—bass that you feel as much as hear, without calling attention to itself.
Done correctly, you don’t hear the subwoofer as a separate source. You simply experience a system that sounds larger, more grounded, and more lifelike.
Full-range speakers are wonderful. But in a real room, with real placement constraints, a subwoofer isn’t a luxury.
It’s the key to unlocking what those speakers are truly capable of.
A hard truth
A hard truth
