Issue 15 • Free Online Magazine
Issue 15 QUIBBLES AND BITS
Sigma–Delta Modulators - Part I
I have mentioned Sigma–Delta Modulators (SDMs) in this column before.  These are, in effect, complex filter structures and they are used to produce DSD and other bitstreams.  I know I talk about DSD a lot, and I also know that digital audio is more about PCM that it ever is – or ever will be – about DSD.  But SDMs are widely used today to make both ADCs and DACs, and so cannot be ignored by anybody who really wants to understand digital audio.  So I thought I would devote a column to an attempt to explain what SDMs are, how they work, and what their limitations are.  This will be doubly taxing, because it is deeply technical subject, and will make for a very long column.  In fact, it will make for two very long columns!  At the end of it all, I will conclude by attempting to place the results of my ramblings in the context of the PCM-vs-DSD debate, with perhaps a surprising result.
The words Sigma and Delta refer to two Greek letters, Σ and Δ, which are used by convention in mathematics to denote addition (Σ) and subtraction (Δ).  Negative feedback, where the output signal is subtracted from the input signal, is a form of Delta modulation.  Similarly, an unstable amplifier, where the output signal is added back into the input signal causing the whole thing to increase uncontrollably, is a form of Sigma modulation.  Sigma–Delta Modulators work by combining those functions into a single complex structure.  I use the term ‘structure’ intentionally, because SDMs can be implemented both in the analog domain (where they would be referred to as circuits) and in the digital domain (where they would be referred to as algorithms).  In this context, analog and digital refer only to the inputs of the SDM, as an SDM’s output is always digital.  For the remainder of this post I will refer only to digital SDMs, mainly because it is easier to describe.  But you should read it all as being equally applicable to the analog case.
At the core of an SDM lies the basic concept of a negative feedback loop.  This is where you take the output of the SDM and subtract it from its input.  We’ll call that the Delta stage.  If the output of the SDM is identical to its input, then the output of this Delta stage will always be zero.  Between the Delta Stage and the SDM output is a Sigma stage.  A Sigma stage works by maintaining an accumulated value to which it adds every input value it receives.  This accumulated value then becomes its output, and the output of the Sigma stage is also the output of the SDM itself.  Therefore, so long as the output of the SDM remains identical to its input, the output of the Delta stage will always be zero, and consequently will continue to add zero to the accumulated output of the Sigma stage which will therefore also remain unchanged.  This is what we call the “steady-state case”.
But music is not steady-state.  It is always changing.  Let’s look at what happens when the input to the SDM increases slightly.  This results in a small difference between the input and the output of the SDM.  This difference appears at the output of the SDM’s Delta stage, and, consequently, at the input of it’s Sigma stage.  This causes the output of the Sigma stage to increase slightly.  The output of the Sigma stage is also the output of the SDM, and so the SDM’s output also increases slightly.  Now, the output of the SDM is once more identical to its input.  The same argument can be followed for a small decrease in the input to the SDM.  The SDM as described here is basically a structure whose output follows its input.  Which makes it a singularly useless construct.
So now we will modify the SDM described above in order to make it useful.  What we will do is to place a Quantizer between the output of the Sigma stage and the output of the SDM, so that the output of the SDM is now the quantized output of the Sigma stage.  This apparently minor change will have dramatic implications.  For a start, this is what gives it its digital-only output.  To illustrate this, we will take it to its logical extreme.  Although we can choose to quantize the output to any bit depth we like, we will elect to quantize it to 1-bit, which means the output can only take on one of two values.  We’ll call these +1 and -1 (although we will represent them digitally using the binary digits 1 and 0).  One result of this is that now the input and output values of the SDM will always be different, and the output of the Delta stage will never be zero.  The SDM is still trying to do the same job, which is to try to make the output signal as close as possible to the input signal.  This would appear to be a losing cause since the output signal is now constrained to taking on only the values +1 or -1 and the input signal occupies the space between them.
At this point, mathematics takes over, and it becomes a challenge to reduce what I am going to describe to simple illustrative concepts.  I hope you will bear with me.
In order to understand what the SDM is actually doing, we need to make some sort of model.  In other words we’ll need a set of equations which describe the SDM’s behavior.  By solving those equations we can gain an understanding of what the SDM is capable of doing, and what its limits are.  There is a problem, though.  The Quantizer is a non-linear element.  If we know what the input value to the Quantizer is, we can determine precisely what the output value will be, but the opposite is not true.  Given the output of the Quantizer, we cannot know a priori what the input value was that resulted in that output value.  We cannot solve equations containing non-linear elements.  The way we tend to approach problems such as this is to consider the Quantizer instead as a noise source.  Instead of trying to model a Quantizer, we consider that we are adding noise (i.e. random values) to the output of the Sigma stage, such that the output values of the SDM just happen to end up being either +1 or -1.
The next thing we do is to observe that one thing we have said about how the SDM works is not entirely correct.  We said that at the input to the Delta stage we take the SDM’s input and subtract from it the SDM’s output.  In fact what we subtract is the SDM’s output at the previous time step.  This is very important, because it means that we can use this one-step delay to express the SDM’s behavior in terms of a digital transfer function, using theories developed to understand how filters work.  When we apply all this gobbledygook to the SDM we come up with two properties that we call the Signal Transfer Function (STF) and the Noise Transfer Function (NTF).  These are two very useful properties.
The STF tells us how much of the signal applied to the input of the SDM makes it through and appears in the output, whereas the NTF tells us how much of the quantization noise generated by the Quantizer makes it to the SDM’s output.  Both of these properties are strongly interrelated, and are strongly frequency dependent.  It would be great if we could arrange for STF~1 and NTF~0 across the low frequencies where the audio band is located.  By contrast, at the high frequencies we won’t care if the STF ends up being ~0 or the NTF ends up being ~1.  So, what exactly does all that gobbledygook mean?
The important thing is that at low frequencies we want the combination of STF~1 and NTF~0.  This means that at these low frequencies the output of the SDM contains all of the signal and none of the Quantization noise.  If we can arrange it such that those “low frequencies” comprise the entire audio frequency band, then our SDM might be capable of encoding that music signal with surprising precision even though the format has a bit depth of only 1-bit.
A simpler way for the performance potential of this SDM to be viewed is to consider just the Quantization noise.  This is nothing more than the difference between what the ideal (not Quantized) input signal looks like and what the actual (Quantized) output signal actually does looks like.  If those differences could be stripped off, then the output signal would be identical to the input signal, which is our perfect ideal.  What the NTF of the SDM has done is to arrange for all of those differences to be concentrated into a certain band of high frequencies which are quite separate from the audio frequency band containing the ideal output.  By the simple expedient of applying a suitable low-pass filter, we can filter them out completely, and thereby faithfully reconstruct the ideal output signal.
Unfortunately, the simplistic SDM I have just described is not quite up to the task I set for it.  The NTF is not good enough to meet our requirements.  In reality, a final step is required in the design of the SDM which will enable us to fine tune the STF and NTF to acquire the characteristics needed to make a high-performance SDM.
In Part II I will discuss how we approach this challenge, and see how well it works.  We will then discuss some of the limitations and challenges of SDM design, and conclude by attempting to place my observations in the context of the PCM-vs-DSD debate
More from Issue 15
View All Articles in Issue 15
#232 What came first: Art or Music? A Conversation With Artist Jose Acosta by Joe Caplan Jul 06, 2026 #232 Blow By Blow: The Jeff Beck Story: An Insightful Book About a Guitar Icon by Ray Chelstowski Jul 06, 2026 #232 Creed Over Camaraderie? by B. Jan Montana Jul 06, 2026 #232 Chronicles of a Sound Pilgrim at the 2026 Montreal Audiofest by Hugues Morin Jul 06, 2026 #232 The Vinyl Beat: Summer Grooves by Rudy Radelic Jul 06, 2026 #232 Hibbing Hillbilly Dylan's Acoustic Rock by Wayne Robins Jul 06, 2026 #232 Quad Quads and Plasmatronics Tweeters: An Extraordinary System Comes to Life by Frank Doris Jul 06, 2026 #232 In Praise of Live Music, Once Again by Ted Shafran Jul 06, 2026 #232 Allnic Audio’s L-9000 Preamplifier: Design and Engineering Innovation by Howard Kneller Jul 06, 2026 #232 “Best Of” Lists and Rage Bait: Enough Already by Frank Doris Jul 06, 2026 #232 Quick Takes: Bud Shank, Paulo Almeida, Jakob Dreyer, Tim Eriksen and Peter Irvine by Frank Doris Jul 06, 2026 #232 My Impressions of AXPONA 2026, Part 2 by Frank Doris Jul 06, 2026 #232 How to Play in a Rock Band, 25: Encounters With Famous Musicians, Part Three by Frank Doris Jul 06, 2026 #232 Budgets, and Systems From Small to Outrageous by Paul McGowan Jul 06, 2026 #232 PS Audio in the News by PS Audio Staff Jul 06, 2026 #232 Hand It Over by Frank Doris Jul 06, 2026 #232 Difference of Opinion by Peter Xeni Jul 06, 2026 #232 Wabi-sabi Tree by James Schrimpf Jul 06, 2026 #231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026
