Stellar Strata MK2
Stellar Strata MK2
Couldn't load pickup availability
Design
Application
Technology
At this instrument's heart is a new analog attenuator that elegantly solves the fundamental problem facing preamp designers. Volume control. Nearly all analog preamplifiers use sonically degrading elements inserted in the signal path to control volume. The MKII eliminates this problem by using an all new no-loss analog attenuator in response to front panel controls. Once the connected source has passed through the Class A analog preamplifier, it's time to connect to your speakers. Here, engineer Darren Myers used the Analog Cell where he could lavish upon the music the sweet, tube-like quality of Class A biased MOSFETs. Combined with the ruler flat high linearity of Strata MK2's high current output stage, richly overlayed layers of music’s inner details are preserved even in the most complex orchestral crescendos.
                Features
Specifications - Stellar Strata MK2
General
| Color Options | Black Silver  |
| Voltage Options | Japan 100V (+/-10%) North America 120V (+/-10%) Europe/Asia 230V (+/-10%)  |
| Mains Power Input | IEC C14 |
| Fuses | T250V-250mAH (1/4A Slow Blow) |
| Accessories Included | Remote Control Line Cord: - US, JP and EX (NEMA 5-15P) - Schuko (CEE7/7) (230V version) - UK (BS1363) (230V version) - Australia (230V version)  |
| Analog Audio Inputs | RCA: 2 stereo pairs XLR: 1 stereo pair  |
| Phono Inputs | MM RCA: 1 stereo pair MC RCA: 1 stereo pair  |
| Digital Audio Inputs | I2S: 2 inputs - PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256 Coax: 2 inputs - PCM 44.1KHz - 192KHz Optical: 1 input - PCM 44.1kHZ - 192KHz USB: 1 input - PCM 44.1kHZ - 384KHz - DSD64, DSD128 (native) - DSD64, DSD128 (DoP)  |
| Audio Outputs | RCA (Unbalanced): 1 stereo pair Headphones: 1 1/4" stereo Speakers: 2 binding post pairs  |
| Other | Trigger Out: 2 3.5mm, 5-15 DVC USB A: 1 (for firmware update)  |
Mechanical
| Unit Dimensions | 17" w x 2.8" h (not including feet) x 13.5" d (with connectors and knobs, chassis only is 12") [43.2cm x 7.1cm x 34.3cm]  |
| Weight | 21 lbs [9.5 kg] |
| Shipping Dimensions | 22" w x 8" h x 17" d [55.9cm x 20.3cm x .4.3cm]  |
| Shipping Weight | 25 lbs [11.4 kg] |
Environmental
| Location | Indoor use only |
| Storage Temperature | -30 to 70C |
| Operating Temperature | 0 to 45C |
Features
| Input Selection | 9 total: 2 analog, 6 digital, 1 Phono |
| Volume Control | 0-100 (80 dB total range) |
| Balance Control | 12dB each direction in 1/4dB steps |
| Fixed Volume Mode | Analog2: adjustable in setup to any level |
| Phase Control | Digital sources only |
| Filter Control | 3 selectable digital filters (PCM digital sources only) |
| Input Trim | Gain adjustable per input +/-10dB |
| Headphone Trim | Gain adjustable +/-10dB relative to speaker level |
Performance
Analog Inputs
| Input Separation | >85dB |
| Input Impedance | 47KΩ (unbalanced); 100KΩ (balanced) |
| Maximum Input Level | >16 VRMS |
Phono Input
| Cartridge/Type | MM | MC |
| Gain | 40dB | 57dB |
| Loading | 100pF/47kΩ | 470pF/100Ω |
| THD+N | .001% @ 5mV input | .003% @1mV input |
Analog Output
| Output Impedance | Line Out 100Ω |
| Gain | Volume=100 6dB +/- 0.5dB  |
Main (Speaker) Out
| Gain (relative to line output) | 30.5dB |
| Output Power | 8Ω, 1KHz, 1% 100W minimum 4Ω, 1KHz, 1% 150W typical  |
| Frequency Response | +/-1dB 20Hz – 20KHz -3dB 7Hz – 40KHz  |
| THD+N | 1KHz, 10W/4Ω 0.02% |
| IMD | 18/19KHz -65dB |
| Speaker Impedance | 4Ω minimum |
| Output Impedance | 50Hz 150 mΩ typical |
| Damping Factor | 50Hz, 4Ω 29 |
| Sensitivity | @76 1.77 VRMS @100 450 VRMS  |
| Channel Separation | 1KHz >90dB |
Headphone Output
| Gain (relative to line output) | 16.5dB |
| Output Power | 300Ω, 1KHz, 1%300mW 16Ω, 1KHz, 1% 3.25W  |
| Frequency Response | +/-1dB 7Hz – 40KHz |
| THD | 1KHz, 1 VRMS 300Ω <0.02% 16Ω <0.02%  |
| S/N Ratio | 1KHz >110dB (max output) |
| Output Noise | < -90dBV |
| Headphone Impedance | 8Ω minimum |
| Output Impedance | <4 Ω |
Power
| Input Voltage | US 108—132VAC (120VAC nominal) EX/GR/UK/AU 207—253VAC (230VAC nominal) JP 90—110VAC (100VAC nominal)  |
| Power Consumption | Idle 20W Typical 50W Maximum 600W  |
