M1200 Amplifier
M1200 Amplifier
Couldn't load pickup availability
Design
Application
Technology
The Stellar M1200 mono amplifiers solve a classic problem with nearly every power amplifier made: sonic compression. When the orchestra gets loud and complex, or the band really starts to rock it out, most power amplifiers get out of their comfort zone and we hear their stress and strain as compression. The M1200 was designed to play any music into any loudspeaker with zero compression. Rated at 600 Watts into 8Ω and a whopping 1200 Watts into 4Ω, the M1200 combines the best of two worlds: ultra-linear, high-current, ICE Edge Class D technology for the output stage; and a discrete, Class-A vacuum tube for the all-important input stage. The M1200’s rich, warm, and beautifully nuanced reproduction of music comes first from the zero feedback, class A vacuum tube input stage. Here nothing is lost in its hand-selected 12AU7 vacuum tube, fed from its own analog power supply.
Features
Specifications - M1200 Amplifier
Stellar M1200 Mono Amplifier |
Unit Weight | 27 lbs [12.2 kg] (each) |
Unit Dimensions | 17”W x 3.75”H x 12”D (13"D w/connectors) 17”W x 7.5”H x 12”D (Stacked) |
Shipping Weight | 29 lbs [13.15 kg] (each) |
Shipping Dimensions | 22”W x 8”H x 17”D (each) |
Color Options | Black Silver |
Vacuum tube type | 12AU7 |
Voltage Options (Factory set only) |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Idle Power Consumption | 27W |
Power Factor | >0.9 @ rated power 4Ω |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs | Copper base nickel plated binding posts (2 pair) |
DC Trigger Input | 3.5mm 5-15VDC |
Warranty | 3 years parts and labor |
Signal |
Gain | 30.5dB +/-0.5dB |
Sensitivity for rated output power | 2.08V |
Signal to Noise | 1kHz@1200 Watts > 112dB |
Input impedance | Unbalanced 50KΩ Balanced 100KΩ |
Output Impedance | 50Hz, 2.8VRMS <0.007Ω |
Damping factor | 50Hz. 2.8VRMS 8Ω >1100 4Ω >550 |
Frequency Response | 2.8VRMS into 4Ω 10Hz – 20KHz +/- 0.5dB 10Hz – 45KHz +0.1/-3.0dB |
THD & IM |
1KHz, 1W/4Ω | < 0.005% |
10-20KHz, 1W/4Ω | < 0.01% |
1KHz, 150W/4Ω | < 0.02% |
Output Power |
120vac mains, 1kHz, 1% THD |
8Ω | 600W minimum |
4Ω | 1200W minimum |
2Ω | Stable for musical transients |
