M1200 Amplifier
M1200 Amplifier
The Stellar M1200 mono amplifiers are a high power super linear amplifier with a vacuum tube input providing uncompressed performance.
The Stellar M1200 monoblock power amplifier combines the rich warmth and musicality of vacuum tubes with the jaw-dropping power and seemingly infinite headroom of a 1200 watt high-performance output stage. This extraordinary hybrid amplifier knows no limits. From the subtlest musical whisperings to the loudest crescendos an orchestra or rock band is capable of, Stellar M1200 never flinches. Regardless of your speaker’s power demands or limitations, enjoy the once unachievable uncompressed effortlessness afforded by this design. Pure musical bliss for any loudspeaker made, from the smallest to the biggest. Stellar.
Regular price
$6,998.00 USD
Regular price
Sale price
$6,998.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - M1200 Amplifier
Stellar M1200 Mono Amplifier |
Unit Weight | 27 lbs [12.2 kg] (each) |
Unit Dimensions | 17”W x 3.75”H x 12”D (13"D w/connectors) 17”W x 7.5”H x 12”D (Stacked) |
Shipping Weight | 29 lbs [13.15 kg] (each) |
Shipping Dimensions | 22”W x 8”H x 17”D (each) |
Color Options | Black Silver |
Vacuum tube type | 12AU7 |
Voltage Options (Factory set only) |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Idle Power Consumption | 27W |
Power Factor | >0.9 @ rated power 4Ω |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs | Copper base nickel plated binding posts (2 pair) |
DC Trigger Input | 3.5mm 5-15VDC |
Warranty | 3 years parts and labor |
Signal |
Gain | 30.5dB +/-0.5dB |
Sensitivity for rated output power | 2.08V |
Signal to Noise | 1kHz@1200 Watts > 112dB |
Input impedance | Unbalanced 50KΩ Balanced 100KΩ |
Output Impedance | 50Hz, 2.8VRMS <0.007Ω |
Damping factor | 50Hz. 2.8VRMS 8Ω >1100 4Ω >550 |
Frequency Response | 2.8VRMS into 4Ω 10Hz – 20KHz +/- 0.5dB 10Hz – 45KHz +0.1/-3.0dB |
THD & IM |
1KHz, 1W/4Ω | < 0.005% |
10-20KHz, 1W/4Ω | < 0.01% |
1KHz, 150W/4Ω | < 0.02% |
Output Power |
120vac mains, 1kHz, 1% THD |
8Ω | 600W minimum |
4Ω | 1200W minimum |
2Ω | Stable for musical transients |
