Skip to product information
NaN of -Infinity
GainCell DAC - Refurbished
The Stellar GainCell DAC combines the benefits of an exceptional analog preamplifier and a full-featured DAC. It's affordable excellence.
The analog preamplifier is the heart and soul of any high-performance audio system. It's the point in a system where music's magic can be won or lost. For more than 45 years, PS Audio has been building preamplifiers that honor the music and preserve the magic. The Stellar Gain Cell DAC is no exception. It features fully balanced class A analog circuitry from input to output, along with a state of the art DAC that ensures perfect symmetry between analog and digital. Rediscover the wealth of music in your library, with Stellar. Rich, sweet, and always a musical treat, Stellar GainCell DAC is our best value in bringing life to music.
You have 14 calendar days to audition a Refurbished item from the date you received it. For more information on PS Audio Refurbished units click here.
Regular price $949.00 USD
Regular price $1,899.00 USD Sale price $949.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    The idea of building a no-loss analog preamplifier with its own built-in cutting edge DAC was the basis of the Stellar GainCell design imperative. At this instrument's heart is the analog GainCell. Rather than using additional sonically-degrading elements inserted in the signal path to control volume, the GainCell eliminates this problem without additional circuitry in the signal path by varying its gain in response to front panel controls. Based on industry leading Sabre32 bit Hyperstream architecture, Stellar DAC features a fully balanced Class A analog output stage with multiple power supplies, independent jitter-reduced inputs, DSD, I2S, and asynchronous USB.
  • Application
    The Stellar GainCell DAC is a full function analog preamplifier featuring a state of the art built in Digital to Analog Converter inside. It is all you need as the basis of a reference quality music system. Add a power amplifier and a pair of loudspeakers and you'll be reveling in sonic bliss within moments. Connect a computer, CD player, or digital source to any of Stellar's multiple digital inputs, or a Stellar Phono Preamplifier to its analog ins, and you've just built one of the highest value music systems in the world.
Technology
Think of the Stellar GainCell DAC as a complete analog control center with an exceptional performing DAC at its heart. All the features and functions you’d ever want in an analog preamplifier and modern DAC are right here in Stellar. A zero-loss, fully balanced, pure, analog signal path combined with DAC features rarely found at any price level: pure DSD, asynchronous USB, Digital Lens technology, I²S to connect to our best transport, balanced throughout. Replace your preamplifier, your DAC—or both—and be stunned at the level of improvement when the full and rich tapestry of music surprises and delights your senses. Together, or separately, they create an extraordinarily rich, full-bodied musical experience few standalone products can match. The Stellar Gain Cell is the perfect foundation for those unwilling to compromise sound quality. Rich. Lush. Powerful. A music lover’s answer to spiraling cost-no-object equipment without sacrifice. In the more than forty years of PS Audio’s design innovations and breakthrough products, Stellar’s groundbreaking level of performance as our gateway standalone DAC and preamplifier is unmatched for price and performance by their standalone competitors. Taken together, we’re willing to bet you’ve never heard anything quite this good at anywhere even remotely close to this price.
  • CLASS A BALANCED ANALOG PREAMPLIFIER
  • FULL FUNCTION DAC
  • CLASS A HEADPHONE OUTPUT
  • FIXED OR VARIABLE DAC MODE
  • ANALOG GAIN CELL STAGE
  • BALANCED XLR OUTPUT
  • HOME THEATER BYPASS
  • DIGITAL LENS TECHNOLOGY
  • THREE SELECTABLE DIGITAL FILTERS
  • CPLD (FPGA) INPUT
  • HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
  • ESS HYPERSTREAM
  • NO CAPACITORS IN OUTPUT SIGNAL PATH
  • HIGH CURRENT CLASS A HYBRID OUTPUT STAGE
  • SINGLE AND DOUBLE RATE DSD
  • DSD DIRECT THROUGH I2S
NaN of -Infinity
Specifications - Gaincell DAC
Physical
Unit Weight 13.5 lbs [6.1 kg]
Unit Dimensions 17” x 12” x 3”
Shipping Weight 17 lbs [7.7 kg]
Shipping Dimensions 23”x 18” x 9”
Power requirements
Input Power Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz
Power Consumption 20W
Mains Power Input IEC C14
Fuses 100V T250V-2.0AH (2A Slow Blow)
120V T250V-1.6AH (1.6A Slow Blow)
230V T250V-1.0AH (1.0A Slow Blow)
Accessories included US (NEMA 5-15P) (all versions)
Schuko (CEE7/7) (230V version)
UK (BS1363) (230V version)
Analog inputs
RCA
XLR
3 stereo pair
1 stereo pair
Digital audio inputs
I2S 1 PCM (384KHz max)
DSD64 DSD128
Compatible with DirectStream Transport SACD handshake for DSD playback
Coax 2 PCM (192KHz max)
Optical 1 PCM (96KHz max)
USB PCM (384KHz max)
DSD64 (DoP) DSD128 (DoP)
Format PCM, DSD
Analog Audio Outputs
RCA
XLR
Headphones
(Analog Unbalanced) 1 stereo pair
(Analog Balanced) 1 stereo pair
One 1/4" headphone connector front panel
Analog Performance
Gain
Maximum output
Sensitivity
12dB +/-0.5dB
20 Vrms
5.3Vrms
Input Impedance 47KΩ single ended RCA
100KΩ Balanced XLR
Output Impedance 100Ω single ended RCA
200Ω balanced XLR
Frequency Response 20Hz – 20KHz +0/- 0.25dB
10Hz – 100KHz +0.1/-3.0dB
Noise 20-20KHz <-90dBV
S/N Ratio 1KHz >110dB (max output)
Channel separation 1KHz >90dB
Input separation 1KHz >90dB
THD&IM 1KHz < 0.025%
20-20KHz < 0.05%
Headphone performance
Output power @1% THD 300Ω 300mW
16Ω 3.25W
S/N Ratio 1kHz
Noise
>95dB (max output)
<-80dBV
THD & IM 1Vrms out 300Ω <0.05%
16Ω <0.06%
Output impedance <4 Ω
Features
Volume Control 0-100 (1/2 and 1dB steps, 80dB total range)
Balance Control 24dB each direction in 1/2dB steps
Home Theater Mode Assignable to any analog input
Adjustable (in setup) to any level
Polarity (phase) Control Digital sources only
Filter Control 3 selectable digital filters (PCM digital sources only)
Trigger output (3.5mm 5-15VDC) 2
Remote Control Yes. Infra Red
Questions?
