DirectStream DAC MK1 - Refurbished
You have 14 calendar days to audition a Refurbished item from the date you received it. For more information on PS Audio Refurbished units click here.
Couldn't load pickup availability
Design
Application
Technology
Features
Specifications - DirectStream DAC
Physical |
Unit Weight | 22 lbs [9.97 kg] |
Unit Dimensions | 14” x 17” x 4” [ 36cm x 43cm x 10cm] |
Shipping Weight | 31 lbs [14 kg] |
Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
Power requirements |
Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
Power Consumption | 30W |
Digital audio inputs |
I2S(2), Coax, XLR Balanced, TOSLINK, USB, Network Bridge slot |
Sample Rates |
I2S, and USB — 44.1kHz to 352.8kHz 16bit, 24bit, DSD 64, DSD 128 (I2S DSD 256 with Sunlight update)
Analog Audio Output |
Connector | RCA/XLR Unbalanced /Balanced (X2) |
Output level, low | 0.282 VRMS Balanced 0.141 VRMS Single Ended |
Output level high, maximum | 2.818 VRMS Balanced 1.414 VRMS Single Ended |
Output Impedance | 100Ω/200Ω |
Frequency Response | 20-20KHz +/- 0.25dB |
THD+N @ 1KHz (full scale) | <0.03% |
Output Stage | Passive audio transformer, fed by high current, high speed analog amps producing double rate DSD. |
Data Handling |
Format | PCM or DSD |
Sample rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz |
Word length (PCM) | 16b, 18b, 20b, 24b |
Data rate (DSD) | Standard (2.8MHz) or Double (5.6MHz) DoP as well as raw DSD on I2S and USB inputs |
Input jitter reduction | effectively 100%, residual immeasurable. No input PLLs, FLLs. |
Input Processing | 170MHz |
Signal Processing | 50MHz |
Synchronous Upsampling, all inputs | 28.224MHz |
Digital Processing S/N ratio | >146 dB |
Digital Volume Control | Zero loss of precision |
Analog Conversion method | Delta Sigma (DSD) Single-bit double rate |
I2S Digital Input |
Connector | HDMI |
Format | PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs |
USB Digital Input |
Connector | USB “B” Type |
Format | PCM or DoP v1.1 (DSD over PCM) |
Transfer mode | Asynchronous |
