BHK Mono 300 Power Amplifier
When you are unwilling to compromise performance we offer the BHK 300 Signature 300 watt Monoblock power amplifiers. They are among a rare handful of amplifiers capable of uncovering music's rich tapestry in a lush, uncompromised, effortless presentation.
The audio performance and build quality of the Signature 300 series has been refined, honed, and polished over the past half century of design work by industry legend, Bascom H. King. They are mono block amplifiers that produce 300 watts into 8Ω, 600 into 4Ω, and a whopping 1,000 watts into 2Ω. The BHK Signature 300 Monoblock designs are built upon two proven topologies: a zero-loss vacuum tube input stage coupled to a high bias differentially balanced MOSFET output. If you are uncomfortable with compromise and seek the finest performance, reliability, and build quality, the BHK Signature 300 series is a perfect fit that can drive any loudspeaker to musical perfection.
Regular price
$16,998.00 USD
Regular price
$16,998.00 USD
Sale price
$16,998.00 USD
Unit price
per
Couldn't load pickup availability
In Home Evaluation
In Home Evaluation
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - BHK Mono 300 Power Amplifier
BHK Signature 250 Stereo and BHK Signature 300 Mono |
Unit Weight | 83 lbs [37.6 kg] |
Unit Dimensions | 17.1” x 8.7” x 14” Chassis only. 15" deep including connectors. |
Shipping Weight | 92 lbs [41.7 kg] |
Shipping Dimensions | 21”x 13” x 19” |
Color Options | Black Silver |
Voltage Options Factory set only |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Fuse Compliment all Countries | 4 - 10 amp fast blow H-Rated 5x20mm Rail Fuses |
Fuse Compliment Mains |
100vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 12 amp slow blow H-rated 5x20mm 120vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 10 amp slow blow H-rated 5x20mm 230vac Countries 1 - 1.6 amp slow blow H-rated 5x20mm 1 - 5 amp slow blow H-rated 5x20mm |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs Signature 250 | Gold plated copper binding posts (2 pair per channel) |
Speaker Outputs Signature 300 | Gold plated copper binding posts (2 pair) |
Other | DC Trigger Input 3.5mm 5-15VDC |
Warranty | 3 years parts and labor on unit 1 year on vacuum tube |
Power Consumption |
@Ready | 75 Watts |
@Idle | 175 Watts |
@Rated power 8Ω | 850 Watts |
@Rated power 4Ω | 1600 Watts |
Signal |
Gain | 30.5dB +/-0.5dB |
Sensitivity for rated output power of 250 watts into 8Ω | 1.3V |
Noise | 100-20KHz <-85dBV |
Input impedance Signature 250 stereo | Unbalanced 100KΩ Balanced 200KΩ |
Input impedance Signature 300 mono | Unbalanced 50KΩ Balanced 100KΩ |
Output Impedance | 50Hz, 2.8VRMS <0.1Ω |
Frequency Response | @2.8VRMS 10Hz – 20KHz +/- 0.1dB 10Hz – 200KHz +0.1/-3.0dB |
THD&IM |
1KHz, 1W/8Ω | <0.01% |
20-20KHz, 1W/8Ω | <0.1% |
1KHz, 200W/8Ω | < 0.1% (120VAC Mains input) |
1KHz, 400W/4Ω | < 0.1% (120VAC Mains input) |
Signature 250 Stereo Amplifier |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
8Ω | 250W minimum |
4Ω | 500W minimum |
2Ω | Stable for musical transients |
Signature 300 Mono Amplifier |
Output Power |
8Ω | 300W minimum |
4Ω | 600W minimum |
2Ω | 1000W |
