Aspen FR10 Loudspeaker
The perfect size loudspeaker for any room.
Hi-Fi News says the Aspen FR10 sets the $10k standard. Check out the rest of the review here.
The ground-breaking Aspen series of loudspeakers sets new standards for what is possible in home audio reproduction. Now, with the introduction of our most compact loudspeaker yet, the FR10, it is finally possible to bring the magic of Aspens into everyone’s home.
The Aspen loudspeaker series represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a speaker that is easily driven with any decent power amplifier, and when not even the most advanced driver manufacturer’s products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, the FR10 will transcend your expectations of what a small floor-standing loudspeaker can do.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold, fits in any size room, with bass that will astound you, the Aspen FR10 is a dream come true.
Regular price
$11,999.00 USD
Regular price
Sale price
$11,999.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
A no compromise affordable loudspeaker
The Aspen FR10 loudspeaker is a full range, state-of-the-art loudspeaker that fits into all rooms and budgets. With room-filling, extraordinarily low bass response down to 30Hz, the Aspen FR10 employs the same planar ribbon technology as its larger counterparts but in a smaller and more affordable package. If you're serious about high-end audio, then the FR10 may just be the perfect speaker for you. Come learn more about this extraordinary loudspeaker.
Setup in minutes
The FR10s arrive at your front door through conventional carriers like UPS and FedEx. Learn how easy it is to unpack and set up these wonderful speakers in just a few minutes.
Design
Application
Technology
Features
Specifications - Aspen FR10 Loudspeaker
Color Options | Satin White, Satin Black |
Enclosure Type | Passive radiator (three 6x9” oval rear-firing) |
High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
Mid Frequency Transducer | 8” planar magnetic with Teonex diaphragm |
Low Frequency Transducer | 2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure |
Crossover Frequency | 550 Hz, 1750 Hz - Linkwitz-Riley 4th order acoustic |
Sensitivity (2.83V @ 1M) | 86.5 dB |
Nominal Impedance | 4 ohm (3.3 ohm minimum impedance) |
Recommended Amplifier Power | 50-200W |
Frequency Response | 32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room |
Dimensions (HxWxD) |
41.5” x 11.75” x 16.25” with base (8” width not including base) |
Net Weight | 75 lbs (34.1 kg) |
