Amperage alchemy
Prev Next
We've briefly discussed getting the digital audio stream into the DAC and then decoding those bits back into a form of analog that gets us a lot closer to being able to play it on our systems.
At the output of the DAC chip we have a series of current steps that need to be converted to voltage steps - a sort of alchemy process like turning lead into gold. These current steps can be thought of like different wattage light bulbs if we want to understand them more easily.
Imagine for a moment that we have 24 light bulbs (like 24 bits), each bulb capable of consuming twice the power of the preceding one and in the process getting twice as bright. We start with a 1 watt light bulb, next we have a 2 watt, then a 4 watt and so on. Each of these bulbs consumes more power - or current - than the otherand the combination of brightness gets us a large range of light: from the very dimmest to the very brightest and everywhere in between.
This is similar to what is happening at the output of your DAC chip. Now take your imagination one more step forward: imagine instead of 24 light bulbs you have only a single light bulb and you feed it different wattages. The total wattage you feed this single bulb creates a unique brightness level that spans a 144dB range which, in audio terms, covers the range from a single air molecule hitting your ear to the noise of a jet blast and everything in between.
Preamplifiers and power amplifiers need voltage on their inputs, not current (power). So we must convert these power steps to voltage steps at the output of our DAC chip. The easiest way to convert current to voltage is to simply pass it through a resistor. Place one end of a resistor at the output of our DAC and the other end goes to ground. Voila! You have a simple current to voltage converter.
One of our very first DACS used just this approach and, if I remember from reading John Atkinson's review of the Devialet integrated, that is also what they do. While this works and is simple, it isn't always the best way to do this because not every DAC appreciates working into a resistor and you start losing linearity and gaining noise.
Most DACS simply place the output of the DAC into a chip op amp's inverting input. Now, I understand this is technical sounding stuff, but it's actually fairly simple. An op amp's inverting input looks like ground to the DAC and it is very happy - somewhat like a zero Ohm resistor. This is the point where a lot of audible trouble can begin to take place.
So important is this conversion process that tomorrow we'll look a bit deeper into it's workings and problems.
Back to blog
Paul McGowan
Founder & CEO
Never miss a post
Subscribe
Related Posts
