The easy road
The easy road
Which part of your system did you upgrade last?
I'll bet it wasn't the speakers.
We upgrade digital because it's easy. A new streamer slides onto a shelf. A firmware update arrives overnight. A better file is a download away. Light boxes, quick swaps, little risk.
Power amplifiers are heavy and need two people with good backs. And new loudspeakers? That's practically moving house. New dimensions, new placement, new negotiations with whoever shares the room. So we keep the speakers and tinker everywhere else.
Here's the irony. The speakers are where the biggest differences live (and power amplifiers come in at a close second).
Loudspeakers are mechanical devices pushing real air, with cones that flex, cabinets that resonate, and crossovers steering the signal between drivers. Driver distortion alone commonly runs at 1 to 2 percent, sometimes more in the bass—orders of magnitude above anything upstream. And the speaker is the only part of the chain that talks directly to the room. More room to improve, more impact when it does.
The easy upgrades are real. A better DAC is audible. A cleaner stream is audible. It's simply that the hard road tends to have the bigger view at the end of it.
Like a fresh coat of paint on the front door of a house with a leaky roof, the easy fix feels great and changes less than we hoped.
Start with the roof.
The easy road
The easy road
