The damping factor myth
Prev Next
Numbers can look impressive, but they don’t always mean what we think they do.
Audiophiles are often drawn to specifications because they seem like objective markers of quality. The trouble is, some of those numbers—like damping factor—can be misleading when taken at face value. A spec that looks heroic on paper may offer little in the way of real-world benefits once it’s connected to loudspeakers in a living room.
So what is damping factor? In simple terms, it’s a ratio. Specifically, it compares the impedance of a loudspeaker (usually around 4 to 8 ohms) to the output impedance of the amplifier. If the amplifier has a very low output impedance, the ratio is high, which in theory gives the amp greater ability to “damp” or control the motion of the speaker driver. That control should matter most in the bass, where large cones continue to move after the electrical signal has stopped.
This concept leads to the assumption that higher damping factors always equal better bass. You’ll see amplifiers advertised with damping factors in the hundreds or even thousands, implying iron-fisted control over woofers. The truth, however, is more complicated. Once an amplifier reaches a damping factor of about 20 to 50, the benefits level off. Beyond that point, the resistance of the speaker’s voice coil, crossover components, and even the cables dominate the equation. Whether the amplifier’s spec says 100 or 1000, the speaker sees little difference.
That’s why amplifiers with wildly different damping factor ratings can sound remarkably similar in terms of bass control. What matters more is the amplifier’s overall ability to deliver current cleanly into a load.
Stability, headroom, and the quality of the power supply all play larger roles than chasing astronomical damping factor figures. A modestly rated amplifier with good design can sound tighter and more convincing than one with a sky-high damping spec but compromised execution elsewhere.
When I listen for bass quality, I don’t think about damping factor at all. I focus on whether bass notes have pitch definition, whether they stop and start with authority, and whether they remain controlled as volume rises. Those qualities are real and audible, and they depend on the amplifier as a whole—not on a single number plucked from the spec sheet.
The myth of damping factor is not that it has no meaning, but that beyond a certain threshold, it has far less influence than many believe. Specs are easy to market. Musical truth is harder to measure, but much easier to hear.
Back to blog
Paul McGowan
Founder & CEO
Never miss a post
Subscribe
Related Posts
1 of 2
