Padded rooms
Padded rooms
Clap your hands in your listening room. What comes back?
If the answer is nothing—a dull thud and then silence—you may have a padded room.
I see it again and again in setup photos: panels on every wall, foam in every corner, absorbers on the ceiling. Some of us can't leave a bare wall alone. I get it. Treatment works, and once you've heard a little help, more seems better.
Except more stops being better surprisingly fast.
Most absorption panels do their best work in the midrange and treble. They soak up a voice's reflections. What they barely touch is the deep bass, which has wavelengths far too long for a two-inch panel to notice. Cover the room and the result is lopsided: the top end goes dead while the bass boom carries on just as before. Acousticians measure this with reverberation time, RT60—how long a sound takes to decay by 60 dB. Drive it too low in the upper frequencies and the room sounds like a closet full of coats.
There's a second casualty. Some reflections are our friends. Sound bouncing gently off the side walls is part of what tells the brain it's in a real space, and it helps the soundstage spread and breathe. Kill all of it and the music clings to the speakers instead of floating free of them.
Imagine what your speakers would sound like played outside without any reflections, or the opposite: in a dead room.
A little treatment is a seasoning.
An overly damped room is dead like the music you're trying to reproduce.
Don't rob the magic.
Padded rooms
Padded rooms
