Making the conversion
If the transport's job is to deliver data cleanly, the DAC's job is to turn that data into music. And it's here, in the digital-to-analog conversion process, that things get wickedly fascinating—and ever so complicated.
On paper, a DAC does something simple: it takes a stream of ones and zeros and converts them into an analog voltage that represents the original waveform. But how it does that makes all the difference.
What matters inside a DAC? Almost everything. The power supply is critical—it has to be clean, stable, and isolated from the digital noise generated by the conversion process itself. The clock is just as important. Even the best data from a transport means nothing if the DAC's timing circuit introduces jitter. We obsess over clocks at PS Audio because we've heard firsthand what a clean, stable clock, coupled with multiple stages of reclocking, does for imaging, depth, and tonal purity.
Then there's the output stage. Some DACs use op-amps. Others use discrete transistors. Still others use transformers or tubes. Each approach has trade-offs, and each colors the sound in its own way. At PS Audio, we've always leaned toward direct-coupled discrete designs because they preserve speed and transparency without adding the sonic signature of a capacitor or transformer in the signal path.
But here's what I've learned over fifty years: a great DAC isn't about choosing the right chip or the fanciest technology. It's about understanding how all these pieces work together and voicing the circuit so it sounds like music, not mathematics. That's why we spent years developing the technology that eventually led to the PMG 512 DAC—not to chase specs, but to chase the feeling of sitting in front of live musicians. The PMG DSD architecture represents everything we've learned about isolation, precision power delivery, and circuit voicing that serves the music.
When a DAC gets it right, digital playback stops being a compromise. It becomes capable of everything music lovers chase—space, air, body, presence—with none of the noise, distortion, or wear that comes with vinyl.
That's not a knock on analog. It's just the truth about what's possible today if you're willing to do the hard work.
