How sensitive are you?
Speaker sensitivity may be the single most misunderstood specification in all of audio.
You see it on the spec sheet as a number like 87 dB or 91 dB, measured at one watt from one meter. What it tells you is how loud the speaker gets for a given amount of amplifier power. A speaker rated at 90 dB sensitivity will produce 90 decibels of sound pressure at one meter with just one watt driving it. Bump up to two watts and you get 93 dB. Four watts gets you 96 dB. Every doubling of power adds only three decibels. That is the critical relationship to understand, and most people have no idea.
The math escalates fast. To get from 90 dB to 100 dB, you need ten watts. To hit 110 dB, you need one hundred watts. Now consider a speaker rated at 84 dB sensitivity. It needs four times the power of a 90 dB speaker to play at the same volume. That means the 84 dB speaker needs four hundred watts to reach the same level that the 90 dB speaker reaches with one hundred. This is why sensitivity matters as much as or more than amplifier power when you are building a system.
In practice, most people listen at average levels around 75 to 85 dB in their rooms, with peaks hitting maybe 95 to 100 dB on loud passages. With a speaker rated at 90 dB sensitivity in a typical room, you need maybe ten to fifty watts for average listening and a hundred watts or more for clean, undistorted peaks. That is well within the range of most decent amplifiers. Drop that sensitivity to 84 dB and suddenly you need serious power to avoid compression on dynamic passages. The amplifier runs out of breath right when the music demands the most.
This is one reason I love the Aspen FR30. Chris designed it with a sensitivity around 90 dB and a stable, easy impedance curve that does not punish amplifiers. You can drive it beautifully with a wide range of amps, from modest integrated units to big monoblock power amplifiers. The speaker lets your amplifier do its job without fighting it.
But then there's the FR5s which we have at home and which we continue to drop jaws at the show with. Those little guys are extraordinary head shakers and yet they are not all that efficient. Fact of the matter is even a Strata MKII can drive them perfectly loud with no compression.
So, yes it all matters, but it's probably not worth getting yourself in a twisted knot over numbers.
Just have a listen and you'll know.
