Copper Magazine · Issue 19 · A free PS Audio publication
Issue 19 QUIBBLES AND BITS
To Be or Not To Be Lossless
What does “lossless” mean in audio terminology?  It seems like a straightforward question, and you will undoubtedly have an answer at the ready that says something along the lines of it being the attribute of an operation which permits you to turn a bunch of numbers into a different bunch of numbers, and then turn them back again exactly as they originally were.  But there are shades to losslessness that bear due consideration.  To be (lossless) or not to be (lossless), that is the question.
As we discussed last time around, a Fourier Transform takes data in the time domain and expresses it anew in the frequency domain.  Both views represent the same data in different ways, and (mathematically) the two views can be losslessly transformed back and forth between one and the other.  Let’s take a single channel track of 60 seconds duration sampled at 44.1kHz.  There are a total of 5,292,000 audio samples.  If I take a Discrete Fourier Transform (DFT) of the whole thing, I end up with a frequency spectrum comprising the frequencies from 0Hz to 22,050Hz, separated into 2,646,001 equally spaced bins (that’s half as many bins as samples, plus one bin).  Within each bin I have both the amplitude and phase of that specific frequency (with the exception of the first and last bins, which have no phase information).
In effect the DFT breaks the data down into the exact mathematical formula for the original waveform.  It will in this case comprise the sum of 2,646,001 different Sine waves.  All I have to do is plug the frequency, amplitude, and phase information from the DFT into each one, sum them all together, and I will have fully reconstructed the original analog waveform.  Think about that.  Because it is a mathematical formula, it means I can calculate the amplitude of the original waveform at any point in time – even at points that lie arbitrarily between those of the actual samples which comprise the sampled data.  This is another way of confirming that the original signal can be perfectly recreated from the sampled data, provided the Nyquist criterion has been met.
This concept is useful, because we can use it to perform some interesting thought experiments.  Suppose I decide to mathematically re-sample that waveform at a sample rate of 176.4kHz, or 4 times the 44.1kHz of the original.  This will give me, in effect, the original 44.1kHz samples, plus an additional 3 new samples equally spaced between each adjacent pair of original samples.  [Here I am choosing to carefully align my 176.4kHz samples so that every fourth sample lines up exactly with one of the original 44.1kHz samples.  I don’t necessarily need to do that.]
First I will observe that if I can perfectly recreate the original waveform using only the original 44.1kHz samples, then the additional samples are quite superfluous.  Second I will also observe that this particular 176,400Hz data stream can be seen as comprising four distinct interleaved 44,100Hz data streams.  I can separate those four data streams out.  One of them will comprise the original 44,100Hz samples, but the others – by necessity – will each comprise slightly different numerical values.  Although they are different, each of these data streams clearly encodes the exact same original analog waveform, and can (and will) recreate it exactly using the procedure I laid out above.  Because of this, each of these different 44,100Hz data streams can therefore be recognized as being lossless transformations of each other.
Let me extend this to a more general principle.  If an analog waveform is strictly band limited, then any two digital samplings of that waveform – provided they are carried out at sample rates that meet the Nyquist criterion, and the sampling is executed with absolute precision and perfect timing – will be lossless transformations of each other.
At the risk of hammering on Fawlty-esque at “the bleedin’ obvious”, let me make the key practical point in all this.  It relates to whether upsampled audio files are any better than “ordinary” 44,100Hz files, from a perspective of fidelity.  If the higher sample rate file was obtained by conversion from the original 44.1kHz file then at best it can be a lossless conversion.  But it can never be inherently better.  Which isn’t the same as saying your DAC can’t make a better job of converting it to analog, but that’s a different matter entirely.
More from Issue 19
View All Articles in Issue 19
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
