Stellar DAC
Stellar DAC
Stellar DAC brings wonderful imaging and musicality to any high-performance system at a price you can afford.
Stellar DAC embodies everything PS Audio has strived for in high-value electronics. From its clean and rich tonal balance to its wickedly wonderful imaging, this DAC can be the centerpiece of your music system. Stellar DAC features a built-in Digital Lens, I²S inputs, adjustable filters, and a hand-matched class-A analog output stage that offers breathtaking clarity and musicality. Rediscover the wealth of music in your library with Stellar. Rich, sweet, and always a musical treat, Stellar DAC is our best value in bringing life to music.
Regular price
$2,199.00 USD
Regular price
$2,199.00 USD
Sale price
$2,199.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - Stellar DAC
Physical | |
Unit Weight | 22.5 lbs [10.2 kg] |
Unit Dimensions | 17"W x 3"H x 12" D [43.18 cm x 7.62 cm x 30.48 cm] |
Shipping Weight | 26 lbs [11.8 kg] |
Shipping Dimensions | 22"W x 8"H x 17"D [55.88 cm x 20.32 cm x 43.18 cm] |
Color Options | Black Silver |
Power requirements | |
Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
Power Consumption | 25W |
Digital audio inputs | |
Inputs | I2S (2), Coax (2), Optical, USB |
Sample Rates | I2S: 2 inputs - PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256 Coax: 2 inputs - PCM 44.1KHz - 192KHz Optical: 1 input - PCM 44.1kHZ - 192KHz USB: 1 input - PCM 44.1kHZ - 384KHz - DSD64, DSD128 (native) - DSD64, DSD128 (DoP) |
Analog Audio Output | |
Connector | RCA single ended, XLR balanced |
Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
Output Impedance | 100Ω / 200Ω |
Frequency Response | 20Hz-20kHz, +/- 0.1dB 10Hz-55kHz, -1dB |
Max Output | 4V RMS Balanced, 2V RMS single-ended |
THD+N @ 1KHz (full scale) | <0.003% at full output |
IMD | <0.004%, CCIF, at full output |
SNR | 110dB, referenced to 4V RMS |
Data Handling | |
Format | PCM or DSD |
Sample Rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz |
Word Length (PCM) | 16-32 bit |
Data Rate (DSD) | Up to DSD256 (11.2MHz) Native |
Digital Volume Control | Yes |
Analog Conversion | ES9018K2M DAC Chip |
I2S Digital Input | |
Connector | HDMI |
Format | PCM or DSD. DoP on all inputs as well as native DSD on |
USB Digital Input | |
Connector | USB "B" Type |
Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
Transfer Mode | Asynchronous |
