Skip to product information
1 of 6
PMG Signature SACD Transport
Receive up to $3,000 when you trade in your PerfectWave SACD Transport.
Locked inside your CD and SACD collection is a treasure trove of music you've never truly heard. How do we know? Because we, like you, know every note of our reference discs—and we were stunned when we heard them through the new PMG Signature SACD Transport. This isn’t just another player. It’s the finest optical disc transport we’ve built in 43 years, and for the first time in our history, our founder has signed his name to it. The PMG Signature SACD Transport is an engineering triumph, designed to extract every nuance and detail from your CDs and SACDs with unmatched precision. With galvanically isolated outputs and ultra-low jitter design, it breathes new life into your CD collection when paired with any DAC. And when connected via I²S, it unlocks the raw DSD layer of your SACDs—delivering what was once hidden to external DACs. This is not nostalgia. This is revelation. The PMG Signature SACD Transport is the ultimate disc playback system—worthy of the name, and the legacy.
Regular price $8,999.00 USD
Regular price Sale price $8,999.00 USD
On Sale Sold out
Trade Up
call
TALK TO A HI-FI SPECIALIST
View full details
Inside the PMG SACD Transport
What makes the PMG SACD Transport so special? Paul takes the cover off and talks about the design.
  • Design
    43 years after the introduction of the CD, PS engineers have continued our quest for perfection in the art of data extraction and delivery so you can finally hear what's been locked away in your CD and SACD collection. The PMG Signature SACD Transport is our most advanced optical disc transport. Our galvanically isolated output stage couples the output of the drive mechanism to the PMG's internal Digital Lens with nothing more than a pulse of energy across space, any hints of noise or ground contamination are eliminated. The results of this complete isolation are magical: a previously unheard level of image separation, openness, and effortless reproduction. Never have we experienced noise levels this low—a seemingly velvet blackness that must be experienced to understand.
  • Application
    CD, data discs, and SACD reproduction is unequaled by any other player we know of. CDs played through the PMG Signature SACD Transport come closer than ever to high-resolution PCM and DSD, uncovering new layers of dimensionality, soundstage, depth, and musicality previously unobtainable in other optical readers or server-based audio systems. Like its predecessor, the PerefectWave SACD Transport, the PMG Signature opens the long-restricted DSD layer of SACD to PS Audio DACs. The PMG will deliver the raw DSD layer of copyright-protected SACD directly into your PS Audio DAC through I²S. This means that you'll uncover the wealth of audio's finest digital medium, DSD, and hear exactly what the mastering engineers who created these discs have enjoyed all along. Hear what you've been missing with the PMG Signature SACD Transport.
    Technology
    If you're like most of us, you still have a cherished library of physical discs. There's something timeless about opening a jewel case or sliding a disc from its sleeve—the feel, the ritual, the music waiting inside. Even in today’s world of streaming, CDs, SACDs, and data discs often deliver the best sound in a system—when paired with a truly exceptional transport. None are finer or better sounding than the PMG Signature SACD Transport. This is our statement piece, and it defines state-of-the-art disc playback. From the first notes, you’ll hear the staggering leap in performance it brings. Its secret? A fully galvanically isolated output stage that physically and electrically separates the delicate digital audio stream from its noisy environment, dramatically lowering jitter and noise. Hear more than you ever imagined from your discs with the PMG Signature SACD Transport—the finest we’ve built in over four decades.
    • SACD/CD/CD-R/CD-RW/DVD-R*/-RW*/+R*/+RW* (*Audio data file only)
    • PLAYS MP3, WMA, AAC, WAV, FLAC, AIFF, DSD, 2xDSD, AND ALAC FROM DISCS OR USB INPUT
    • 2x BNC (COAX) OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
    • USB DATA INPUT FOR STORED DIGITAL MEDIA
    • SACS DSD LAYER AVAILABLE THROUGH I2S OUTPUT
    • ADVANCED DIGITAL LENS TECHNOLOGY
    • I2S OUTPUT FOR PCM AND DSD (RAW)
    • 2x XLR OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
    • MEMORY PLAYER TRANSPORT
    • GALVANICALLY ISOLATED OUTPUT STAGE
    • 1x RCA (COAX) OUTPUT FOR PCM AND DOP
    • LARGE ANALOG POWER SUPPLY
    • SEPARATE POWER REGULATORS
    • FPGA SIGNAL PROCESSING
    • NEAR-FIELD LATCH PLACEMENT
    • ZERO SETUP, JUST PLUG AND PLAY
    • CHASSIS WITHIN A CHASSIS FOR THE QUIETEST PERFORMANCE
    • REMOTE CONTROL
    1 of 18
    Specifications - PMG Signature SACD Transport
    Physical
    Unit Weight 30.3 lbs (13.7kg)
    Unit Dimensions 14 3/4” x 17 1/2” x 4 3/8” (with feet)
    375 mm x 445 mm x 112 mm (with feet)
    Shipping Weight 40.5 lbs (18.4 kg)
    Shipping Dimensions 20 1/2” x 24” x 10”
    521 mm x 610 mm x 254 mm
    Color Options Black
    Silver
    Power Requirements
    Input Power 120VAC or 230VAC 50 or 60Hz
    Power Consumption 25W
    Media
    Optical discs SACD/CD/CD-R/CD-RW/
    USB Drive USB Flash Drive with audio files
    Supported File Formats MP3/WMA/AAC (~48kHz/320bps)
    WAV/FLAC/AIFF (~192kHz/24bit)
    ALAC (~96kHz/24bit)
    DSD (~5.6MHz)
    Outputs
    I2S 1 I2S output for PCM and DSD (raw)
    Coax 1 output for PCM and DoP
    BNC 2 outputs for PCM and DoP
    Use in tandem for double-rate DoP
    XLR Balanced 2 outputs for PCM and DoP
    • PS Audio Forum
      I received my Transport yesterday (exquisitely packaged by the way) and got it installed. I am blown away! The debut SACD was Steely Dan’s “Aja” by Analogue Productions and it has never sounded better. Superb product and a very pleased customer!
      July 29, 2025
    Questions?
