PMG Signature SACD Transport
Couldn't load pickup availability
Inside the PMG SACD Transport
Design
Application
Technology
If you're like most of us, you still have a cherished library of physical discs. There's something timeless about opening a jewel case or sliding a disc from its sleeve—the feel, the ritual, the music waiting inside. Even in today’s world of streaming, CDs, SACDs, and data discs often deliver the best sound in a system—when paired with a truly exceptional transport. None are finer or better sounding than the PMG Signature SACD Transport. This is our statement piece, and it defines state-of-the-art disc playback. From the first notes, you’ll hear the staggering leap in performance it brings. Its secret? A fully galvanically isolated output stage that physically and electrically separates the delicate digital audio stream from its noisy environment, dramatically lowering jitter and noise. Hear more than you ever imagined from your discs with the PMG Signature SACD Transport—the finest we’ve built in over four decades.
Features
Specifications - PMG Signature SACD Transport
Physical |
| Unit Weight | 30.3 lbs (13.7kg) |
| Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
| Shipping Weight | 40.5 lbs (18.4 kg) |
| Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
| Color Options | Black Silver |
Power Requirements |
| Input Power | 120VAC or 230VAC 50 or 60Hz |
| Power Consumption | 25W |
Media |
| Optical discs | SACD/CD/CD-R/CD-RW/ DVD-R*/-RW*/+R*/+RW* (*Audio data file only) |
| USB Drive | USB Flash Drive with audio files |
| Supported File Formats | MP3/WMA/AAC (~48kHz/320bps) WAV/FLAC/AIFF (~192kHz/24bit) ALAC (~96kHz/24bit) DSD (~5.6MHz) |
Outputs |
| I2S | 1 I2S output for PCM and DSD (raw) |
| Coax | 1 output for PCM and DoP |
| BNC | 2 outputs for PCM and DoP
Use in tandem for double-rate DoP |
| XLR Balanced | 2 outputs for PCM and DoP
