Get Closer to the Music
The PMG Transport connects your DAC to the hidden magic that's been locked away in your discs. You won't believe what you've been missing!
PMG Signature SACD Transport
Locked inside your CD and SACD collection is a treasure trove of music you've never truly heard. How do we know? Because we, like you, know every note of our reference discs—and we were stunned when we heard them through the new PMG Signature SACD Transport. This isn’t just another player. It’s the finest optical disc transport we’ve built in 43 years, and for the first time in our history, our founder has signed his name to it.
The PMG Signature SACD Transport is an engineering triumph, designed to extract every nuance and detail from your CDs and SACDs with unmatched precision. With galvanically isolated outputs and ultra-low jitter design, it breathes new life into your CD collection when paired with any DAC. And when connected via I²S, it unlocks the raw DSD layer of your SACDs—delivering what was once hidden to external DACs.
This is not nostalgia. This is revelation. The PMG Signature SACD Transport is the ultimate disc playback system—worthy of the name, and the legacy.
Regular price
$300.00 USD
Regular price
Sale price
$300.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - PMG Signature SACD Transport
Physical |
Unit Weight | 30 lbs [13.6 kg] |
Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
Shipping Weight | 40 lbs [18.2 kg] |
Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
Color Options | Black Silver |
Power Requirements |
Input Power | 120VAC or 230VAC 50 or 60Hz |
Power Consumption | 30W |
Media |
Optical discs | SACD/CD/CD-R/CD-RW/ DVD-R*/-RW*/+R*/+RW* (*Audio data file only) |
USB Drive | USB Flash Drive with audio files |
Supported File Formats | MP3/WMA/AAC (~48kHz/320bps) WAV/FLAC/AIFF (~192kHz/24bit) ALAC (~96kHz/24bit) DSD (~5.6MHz) |
Outputs |
I2S | 1 I2S output for PCM and DSD (raw) |
Coax | 1 output for PCM and DoP |
BNC | 2 outputs for PCM and DoP
Use in tandem for double-rate DoP |
XLR Balanced | 2 outputs for PCM and DoP
RJ45 and WIFI | Ethernet and WIFI for over-the-air code updates |
